[codes-ross-users] Help needed in running codes.
Sughosh Divanji sdivanji at hawk.iit.edu
Thu Feb 26 20:37:54 CST 2015
Hi Jonathan,
Thanks for the info. I have setup CODESBASE,CODESNET and ROSS environment
variables and tried to run example.c. However, compiling is failing because
of the following reason.
sughosh at sughosh-Lenovo-G50-45:~/Desktop/IITC/CS597/codes-base/doc/example$
make
make: /home/sughosh/Desktop/IITC/CS597/ROSS/bin/ross-config: Command not
found
found
found
found
I/home/sughosh/Desktop/IITC/CS597/codes-base/include
-I/home/sughosh/Desktop/IITC/CS597/codes-net/include/codes
 -L/home/sughosh/Desktop/IITC/CS597/codes-base/lib
-L/home/sughosh/Desktop/IITC/CS597/codes-net/lib  example.c   -lcodes-net
-lcodes-base  -o example
make: I/home/sughosh/Desktop/IITC/CS597/codes-base/include: Command not
found
make: [example] Error 127 (ignored)
bin directory is not prsent in my ROSS installation and the same with other
errors as well.
I tried compiling codes-base 0.3.0 but it was failing at
src/util/codes_mapping.c:483:51
as I have indicated in my earlier mail. So, I downloaded the source code
from the git link mentioned in Developer Access page,
http://git.mcs.anl.gov/radix/codes-base and git.mcs.anl.gov/radix/codes-net and
was able to compile codes-base and codes-net succesfully. For ROSS I have
downloaded source code from https://github.com/carothersc/ROSS.
Sughosh
ᐧ
On Thu, Feb 26, 2015 at 8:51 AM, Jenkins, Jonathan P. <jenkins at mcs.anl.gov>
wrote:
>  Hi Sughosh,
>  Instructions to build CODES (codes-base and codes-net repositories) can
> be found in their respective INSTALL documents. An example program,
> requiring codes-base and codes-net, can be found in codes-base/doc/example.
> To build it, you need to specify the paths to the codes installs via the
> CODESBASE, CODESNET, and ROSS environment variables. Details of the program
> as well as the CODES components utilized by the program can be found in the
> GETTING_STARTED document.
>  Additionally, what version / revision of ROSS/CODES are you using? We're
> in the midst of some changes on the master branches, so it's probably safer
> to start with the 0.3.0 releases with the ROSS revision specified in the
> INSTALL document.
>  John
>   From: Sughosh Divanji <sdivanji at hawk.iit.edu>
> Date: Wednesday, February 25, 2015 at 7:26 PM
> To: "codes-ross-users at lists.mcs.anl.gov" <
> codes-ross-users at lists.mcs.anl.gov>, Raghav Kapoor <rkapoor7 at hawk.iit.edu>,
> Ke Wang <kwang22 at hawk.iit.edu>
> Subject: [codes-ross-users] Help needed in running codes.
>   Hi,
>  I am trying to use codes for my project and I am new to codes. I have
> installed codes. Can you provide me a sample hello-world program and
> instructions on how to run it. I haven't been able to find documentation on
> how to run the programs and also make files seem to be broken.
>  Thanks,
> Sughosh
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20150226/3f9aa472/attachment.html>
More information about the codes-ross-users mailing list
