[codes-ross-users] Help needed in running codes.
Jenkins, Jonathan P. jenkins at mcs.anl.gov
Thu Feb 26 08:51:08 CST 2015
Hi Sughosh,
Instructions to build CODES (codes-base and codes-net repositories) can be found in their respective INSTALL documents. An example program, requiring codes-base and codes-net, can be found in codes-base/doc/example. To build it, you need to specify the paths to the codes installs via the CODESBASE, CODESNET, and ROSS environment variables. Details of the program as well as the CODES components utilized by the program can be found in the GETTING_STARTED document.
Additionally, what version / revision of ROSS/CODES are you using? We're in the midst of some changes on the master branches, so it's probably safer to start with the 0.3.0 releases with the ROSS revision specified in the INSTALL document.
John
From: Sughosh Divanji <sdivanji at hawk.iit.edu<mailto:sdivanji at hawk.iit.edu>>
Date: Wednesday, February 25, 2015 at 7:26 PM
To: "codes-ross-users at lists.mcs.anl.gov<mailto:codes-ross-users at lists.mcs.anl.gov>" <codes-ross-users at lists.mcs.anl.gov<mailto:codes-ross-users at lists.mcs.anl.gov>>, Raghav Kapoor <rkapoor7 at hawk.iit.edu<mailto:rkapoor7 at hawk.iit.edu>>, Ke Wang <kwang22 at hawk.iit.edu<mailto:kwang22 at hawk.iit.edu>>
Subject: [codes-ross-users] Help needed in running codes.
I am trying to use codes for my project and I am new to codes. I have installed codes. Can you provide me a sample hello-world program and instructions on how to run it. I haven't been able to find documentation on how to run the programs and also make files seem to be broken.
Sughosh
[https://mailfoogae.appspot.com/t?sender=ac2RpdmFuamlAaGF3ay5paXQuZWR1&type=zerocontent&guid=adac9d11-7eb1-4e92-9a7d-3d8934318039]ᐧ
URL: <http://lists.mcs.anl.gov/pipermail/codes-ross-users/attachments/20150226/18ac51ae/attachment.html>
More information about the codes-ross-users mailing list
