[cgma-dev] iGeom Question
Grindeanu, Iulian R. iulian at mcs.anl.gov
Thu Feb 26 12:03:03 CST 2015
Are the curves in  a plane?
Are there other types you can try for the surface type?
Iulian
From: cgma-dev-bounces at mcs.anl.gov [cgma-dev-bounces at mcs.anl.gov] on behalf of Andrew Davis [andrew.davis at wisc.edu]
Sent: Thursday, February 26, 2015 11:44 AM
To: cgma-dev at mcs.anl.gov
Subject: [cgma-dev] iGeom Question
Hi Guys
I'm making some modification to iGeom to allow degenerate tori, I've done this by adding functions which create vertices (points), curves (edges) and a function that takes curve and makes a surface.
Now, so I wrapped make_RefFace
 RefFace* tmp_surface =  gmt->make_RefFace(PLANE_SURFACE_TYPE,
                                            curves,
                                            true);
My curve argument is a DLIList of RefEdges*, Ive written out the state of igeom before this call into a sat file, and I can see my vertices, and curves, but I get a segfault from within BridgeManager::topology_bridge -> GeometryModifyTool::common_modify_engine -> GeometryModifyTool::make_RefFace
Do you guys have any suggestions?
Thanks
Andy
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20150226/784de767/attachment.html>
More information about the cgma-dev mailing list
