[cgma-dev] iGeom Question
Andrew Davis
andrew.davis at wisc.edu
Thu Feb 26 11:44:47 CST 2015
Hi Guys
I'm making some modification to iGeom to allow degenerate tori, I've done
this by adding functions which create vertices (points), curves (edges) and
a function that takes curve and makes a surface.
Now, so I wrapped make_RefFace
RefFace* tmp_surface = gmt->make_RefFace(PLANE_SURFACE_TYPE,
curves,
true);
My curve argument is a DLIList of RefEdges*, Ive written out the state of
igeom before this call into a sat file, and I can see my vertices, and
curves, but I get a segfault from within BridgeManager::topology_bridge
-> GeometryModifyTool::common_modify_engine
-> GeometryModifyTool::make_RefFace
Do you guys have any suggestions?
Thanks
Andy
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20150226/f8db8ebe/attachment.html>
More information about the cgma-dev
