[cgma-dev] CGM make check failure help
Vishal Patel
vpatel314 at gmail.com
Tue Oct 14 00:47:34 CDT 2014
Great, thanks for the link to their github. Now to figure out what I'm
doing wrong installing lasso (moab worked nicely though).
Thanks again,
Vishal Patel
Graduate Researcher
Nuclear Engineering
Texas A&M University
On Mon, Oct 13, 2014 at 11:41 PM, Rajeev Jain <celibate_raj at yahoo.com>
wrote:
> Thanks for getting back.
> For the latest version of RGG GUI you might want to install the GUI from
> Kitware github page:
> https://github.com/Kitware/RGG
> or download binaries:
> http://www.computationalmodelbuilder.org/rgg/
> Rajeev
> *From:* Vishal Patel <vpatel314 at gmail.com>
> *To:* "Jain, Rajeev" <jain at mcs.anl.gov>
> *Sent:* Tuesday, October 14, 2014 6:34 AM
> *Subject:* Re: [cgma-dev] CGM make check failure help
> Hi,
> Thanks for that, Cubit 14.0 worked.
> Thanks,
> Vishal Patel
> Graduate Researcher
> Nuclear Engineering
> On Mon, Oct 6, 2014 at 6:42 PM, Rajeev Jain <jain at mcs.anl.gov> wrote:
> Set LD_LIBRARY_PATH to CUBIT's bin directory. If that doesn't work try
> using Cubit14.0 see this build
> http://gnep.mcs.anl.gov:8010/builders/cgm-cubit/builds/1674
> On OSX use 32bit configure options, since CUBIT doesn't have a 64bit
> version for OSX.
> Rajeev
> ________________________________
> From: Vishal Patel <vpatel314 at gmail.com>
> To: "cgma-dev at mcs.anl.gov" <cgma-dev at mcs.anl.gov>
> Sent: Monday, October 6, 2014 7:22 PM
> Subject: [cgma-dev] CGM make check failure help
> Howdy,
> I'm a graduate researcher at the INL working for the Center for Space
> Nuclear Research. I'm trying to install the reactor geometry generation
> dependencies which needs meshkit which needs cgm and I'm running into some
> trouble I was hoping you could help me with. I'm trying to build CGM with
> cubit on Linux 14.04 LTS and get errors when I make check my installation:
> .so ../.libs/libcgm.so -lm -Wl,-rpath -Wl,/home/patevk/lib/serial/cgm/lib
> -Wl,-rpath -Wl,/home/patevk/opt/Cubit-14.1-Lin64/bin
> ./.libs/libiGeom.so: undefined reference to
> `GeometryQueryTool::translate(Body*, CubitVector const&, bool, bool)'
> `GeometryQueryTool::rotate(BasicTopologyEntity*, CubitVector const&,
> double, bool, bool)'
> `CubitMessage::print_error(char const*, ...)'
> `GeometryQueryTool::translate(BasicTopologyEntity*, CubitVector const&,
> bool, bool)'
> `GeometryQueryTool::reflect(DLIList<Body*>, CubitVector const&, CubitVector
> const&, bool)'
> ./.libs/libiGeom.so: undefined reference to `CubitString::operator==(char
> const*) const'
> `GeometryQueryTool::reflect(BasicTopologyEntity*, CubitVector const&,
> `GeometryQueryTool::rotate(Body*, CubitVector const&, double, bool, bool)'
> It seems my cubit path is being referenced fine and it also exists in my
> LD_LIBRARY_PATH.
> I'm using the CGMA-14.1 pre package, and I've tried the nightly build as
> well as 13.1 with the same errors occurring. I am configuring with:
> ./configure --enable-shared --prefix=/home/patevk/lib/serial/cgm
> --with-cubit=/home/patevk/opt/Cubit-14.1-Lin64 --enable-debug
> I've also tried installing CGM on my OSX machine but can't get Cubit
> libraries to link.
> Any help would be wonderful.
> Thanks,
> Vishal Patel
> Graduate Researcher
> Nuclear Engineering
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20141013/b7b3005e/attachment.html>
More information about the cgma-dev
