[cgma-dev] CGM make check failure help
Rajeev Jain
celibate_raj at yahoo.com
Tue Oct 14 00:41:33 CDT 2014
Thanks for getting back.
For the latest version of RGG GUI you might want to install the GUI from Kitware github page:
https://github.com/Kitware/RGG
or download binaries:
http://www.computationalmodelbuilder.org/rgg/
Rajeev
To: "Jain, Rajeev" <jain at mcs.anl.gov>
Sent: Tuesday, October 14, 2014 6:34 AM
Subject: Re: [cgma-dev] CGM make check failure help
Thanks for that, Cubit 14.0 worked.
Vishal Patel
Graduate Researcher
Nuclear Engineering
Texas A&M University
On Mon, Oct 6, 2014 at 6:42 PM, Rajeev Jain <jain at mcs.anl.gov> wrote:
Set LD_LIBRARY_PATH to CUBIT's bin directory. If that doesn't work try using Cubit14.0 see this build http://gnep.mcs.anl.gov:8010/builders/cgm-cubit/builds/1674
>On OSX use 32bit configure options, since CUBIT doesn't have a 64bit version for OSX.
>Rajeev
>________________________________
>From: Vishal Patel <vpatel314 at gmail.com>
>To: "cgma-dev at mcs.anl.gov" <cgma-dev at mcs.anl.gov>
>Sent: Monday, October 6, 2014 7:22 PM
>Subject: [cgma-dev] CGM make check failure help
>Howdy,
>I'm a graduate researcher at the INL working for the Center for Space Nuclear Research. I'm trying to install the reactor geometry generation dependencies which needs meshkit which needs cgm and I'm running into some trouble I was hoping you could help me with.
I'm trying to build CGM with cubit on Linux 14.04 LTS and get errors when I make check my installation:
>.so ../.libs/libcgm.so -lm -Wl,-rpath -Wl,/home/patevk/lib/serial/cgm/lib -Wl,-rpath -Wl,/home/patevk/opt/Cubit-14.1-Lin64/bin
>./.libs/libiGeom.so: undefined reference to `GeometryQueryTool::translate(Body*, CubitVector const&, bool, bool)'
>./.libs/libiGeom.so: undefined reference to `GeometryQueryTool::rotate(BasicTopologyEntity*, CubitVector const&, double, bool, bool)'
>./.libs/libiGeom.so: undefined reference to `CubitMessage::print_error(char const*, ...)'
>./.libs/libiGeom.so: undefined reference to `GeometryQueryTool::translate(BasicTopologyEntity*, CubitVector const&, bool, bool)'
>./.libs/libiGeom.so: undefined reference to `GeometryQueryTool::reflect(DLIList<Body*>, CubitVector const&, CubitVector const&, bool)'
>./.libs/libiGeom.so: undefined reference to `CubitString::operator==(char const*) const'
>./.libs/libiGeom.so: undefined reference to `GeometryQueryTool::reflect(BasicTopologyEntity*, CubitVector const&, CubitVector const&, bool, bool)'
>./.libs/libiGeom.so: undefined reference to `GeometryQueryTool::rotate(Body*, CubitVector const&, double, bool, bool)'
>It seems my cubit path is being referenced fine and it also exists in my LD_LIBRARY_PATH.
>I'm using the CGMA-14.1 pre package, and I've tried the nightly build as well as 13.1 with the same errors occurring. I am configuring with:
>./configure --enable-shared --prefix=/home/patevk/lib/serial/cgm --with-cubit=/home/patevk/opt/Cubit-14.1-Lin64 --enable-debug
>I've also tried installing CGM on my OSX machine but can't get Cubit libraries to link.
>Any help would be wonderful.
>Thanks,
>Vishal Patel
>Graduate Researcher
>Nuclear Engineering
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20141013/b90aaad4/attachment.html>
More information about the cgma-dev
