[cgma-dev] CGM make check failure help
Vishal Patel vpatel314 at gmail.com
Mon Oct 6 19:22:35 CDT 2014
Howdy,
I'm a graduate researcher at the INL working for the Center for Space
Nuclear Research. I'm trying to install the reactor geometry generation
dependencies which needs meshkit which needs cgm and I'm running into some
trouble I was hoping you could help me with. I'm trying to build CGM with
cubit on Linux 14.04 LTS and get errors when I make check my installation:
.so ../.libs/libcgm.so -lm -Wl,-rpath -Wl,/home/patevk/lib/serial/cgm/lib
-Wl,-rpath -Wl,/home/patevk/opt/Cubit-14.1-Lin64/bin
./.libs/libiGeom.so: undefined reference to
`GeometryQueryTool::translate(Body*, CubitVector const&, bool, bool)'
`GeometryQueryTool::rotate(BasicTopologyEntity*, CubitVector const&,
double, bool, bool)'
./.libs/libiGeom.so: undefined reference to `CubitMessage::print_error(char
const*, ...)'
`GeometryQueryTool::translate(BasicTopologyEntity*, CubitVector const&,
bool, bool)'
`GeometryQueryTool::reflect(DLIList<Body*>, CubitVector const&, CubitVector
const&, bool)'
./.libs/libiGeom.so: undefined reference to `CubitString::operator==(char
const*) const'
`GeometryQueryTool::reflect(BasicTopologyEntity*, CubitVector const&,
`GeometryQueryTool::rotate(Body*, CubitVector const&, double, bool, bool)'
It seems my cubit path is being referenced fine and it also exists in my
LD_LIBRARY_PATH.
I'm using the CGMA-14.1 pre package, and I've tried the nightly build as
well as 13.1 with the same errors occurring. I am configuring with:
./configure --enable-shared --prefix=/home/patevk/lib/serial/cgm
--with-cubit=/home/patevk/opt/Cubit-14.1-Lin64 --enable-debug
I've also tried installing CGM on my OSX machine but can't get Cubit
libraries to link.
Any help would be wonderful.
Vishal Patel
Graduate Researcher
Nuclear Engineering
Texas A&M University
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20141006/e14a5fb2/attachment.html>
More information about the cgma-dev mailing list
