[cgma-dev] copying iGeom entities in occ...
Paul Wilson wilsonp at engr.wisc.edu
Wed Aug 6 02:17:37 CDT 2014
Hi all,
So....
It seems that finish_copy() is called from 3 places.
  * make_RefEdge() - effectively a copy operation of a refEdge
  * make_RefFace() - effectively a copy operation of a RefFace
  * copy_body() - effectively a copy operation for a Body
The first 2 of these already have Boolean arguments with default values
that determine whether or not finish_copy() is called.
The last of these does not have such a Boolean argument and always calls
finish_copy().
I'll note that there is also a method called prepare_for_copy() that is
always called under the same conditions as, but before finish_copy().
I'm a little stumped about what exactly finish_copy() does since it
_/appears to/_ delete all the attributes, but it is called when the
"copy_attribs" flag is true for make_RefEdge().
I hesitated from digging deeper into the prepare_for_copy() and
finish_copy() methods but I wonder if there is something happening that
we don't see in their calls to:
  * GeometryQueryTool::instance()->ige_export_geom() [from
    prepare_for_copy], and
  * GeometryQueryTool::instance()->ige_import_geom() [from finish_copy]
Some of the concepts get pretty involved at this point...
Paul
On 08/05/2014 04:57 PM, Timothy Tautges wrote:
> Remember, changing the interface will break compatibility with cubit.
> Also, this approach looks like flailing without understanding why the
> behavior is coded the way it is.  Finally, iGeom should provide an
> interface to exactly the same code behavior as CGM functions do, and
> modifications meant only to change behavior between cgm vs iGeom
> interfaces should not be done.
> On Aug 5, 2014 10:13 PM, "Rajeev Jain" <jain at mcs.anl.gov
> <mailto:jain at mcs.anl.gov>> wrote:
>     Hi Patrick,
>     Good work.
>     How about we make another argument to the copy function?
>     With this argument the blue code will be controlled. The
>     argument's default will be true -> so nothing changes.
>     For your application the argument will be false (don't clear the
>     attributes of the copied entities).
>     Rajeev
>     *From:* shriwise <shriwise at wisc.edu <mailto:shriwise at wisc.edu>>
>     *To:* "cgma-dev at mcs.anl.gov <mailto:cgma-dev at mcs.anl.gov>"
>     <cgma-dev at mcs.anl.gov <mailto:cgma-dev at mcs.anl.gov>>
>     *Sent:* Tuesday, August 5, 2014 3:49 PM
>     *Subject:* Re: [cgma-dev] copying iGeom entities in occ...
>     A little more info. Looks like this problem comes from the
>     finish_copy call in GMT. If I comment the lines in blue, my new
>     functions for copying tag data from one entity to another work as
>     expected.
>     My thought is to add a flags for these functions with regards to
>     copying entity tag data/ attribute info. In the GMT functions the
>     default will maintain the status quo (do not copy the attribute
>     data) whereas in the iGeom interface the default will be to copy
>     the tag/attribute data. Does this sound acceptable for now? As of
>     yet this is the only change I will need to make outside of the
>     itaps dir in CGM.
>     Cheers,
>     Patrick
>     CubitStatus GeometryModifyTool::finish_copy( TopologyBridge
>     *&new_bridge,
>     TopologyBridge *old_bridge )
>       //Remove attributes on underlying entities of virtual geometry
>       //entities which do not have corresponding RefEntities.
>       DLIList<TopologyBridge*> bridge_list;
>       bridge_list.append( old_bridge );
>     GeometryQueryTool::instance()->ige_remove_attributes( bridge_list );
>     //Remove attributes on original entity and children
>       DLIList<RefEntity*> child_list;
>     RefEntity *ref_ent = CAST_TO( old_bridge->topology_entity(),
>     RefEntity );
>       ref_ent->get_all_child_ref_entities( child_list );
>       //child_list.append( ref_ent );
>       CubitAttribUser::clear_all_simple_attrib( child_list );
>       child_list.clean_out();
>       //Restore virtual
>       //Could create virtual geometry here so the Topology Bridge can
>     change
>       bridge_list.clean_out();
>       bridge_list.append( new_bridge );
>       TopologyBridge *tmp_bridge_before = new_bridge;
>     GeometryQueryTool::instance()->ige_import_geom( bridge_list );
>       assert( bridge_list.size() == 1 );
>       if( tmp_bridge_before != bridge_list.get() )
>         new_bridge = bridge_list.get();
>       //make the RefEntities
>       Curve *curve = NULL;
>       Surface *surface = NULL;
>       Lump *lump = NULL;
>       BodySM *body = NULL;
>       RefEntity *new_ref_ent = NULL;
>       if( (curve = CAST_TO( new_bridge, Curve ) ) != NULL )
>         new_ref_ent = GeometryQueryTool::instance()->make_RefEdge(
>     curve );
>       else if( (surface = CAST_TO( new_bridge, Surface) ) != NULL )
>         new_ref_ent = GeometryQueryTool::instance()->make_RefFace(
>     surface );
>       else if( (lump = CAST_TO( new_bridge, Lump) ) != NULL )
>         new_ref_ent = GeometryQueryTool::instance()->make_Body(
>     lump->bodysm() );
>       else if( (body = CAST_TO( new_bridge, BodySM) ) != NULL )
>         new_ref_ent = GeometryQueryTool::instance()->make_Body( body );
>       //actuate the attributes on everything
>       new_ref_ent->get_all_child_ref_entities( child_list );
>       child_list.append( new_ref_ent );
>       GeometryQueryTool::import_actuate( child_list );
>       //Remove attributes on new entity and children
>     CGMApp::instance()->restore_previous_attribute_states();
>       return CUBIT_SUCCESS;
>     On 08/05/2014 03:18 PM, shriwise wrote:
>>     Just checked and this fails when built w/ CUBIT as well.
>>     Patrick
>>     On 08/05/2014 03:13 PM, shriwise wrote:
>>>     Hi all,
>>>     I just ran into an interesting problem in CGM built with OCC.
>>>     When an entity is copied, the original loses all user-applied
>>>     tag information (or so it seems). I understand why a copy might
>>>     not keep data from the original, but for the data to disappear
>>>     from the original altogether seems like incorrect behaviour to me.
>>>     I wrote a test as an example of this below. The test fails on
>>>     the red line. Any ideas as to why? I've tracked the number of
>>>     tags on the entity and they seem to disappear in line 5804 of
>>>     iGeom_CGMA.cc.
>>>     Any help or insight for this would be very appreciated! I'm
>>>     close to finishing my updates to the iGeom interface and this
>>>     seems to be the last piece of the puzzle.
>>>     bool tag_copied_ent_test(iGeom_Instance geom)
>>>       int err;
>>>       //create a tag
>>>       iBase_TagHandle test_tag;
>>>       std::string name("test_tag");
>>>       iGeom_createTag(geom, &name[0], 1, iBase_INTEGER, &test_tag,
>>>     &err, name.length());
>>>       CHECK( "ERROR: could not create tag" );
>>>       //create a test entity
>>>       iBase_EntityHandle cyl;
>>>       iGeom_createCylinder(geom, 5.0, 5.0, 0.0, &cyl, &err);
>>>       CHECK( "ERROR: could not create the cylinder" );
>>>       //set a value for this tag on the original
>>>       int value = 6;
>>>       iGeom_setIntData(geom, cyl, test_tag, value, &err);
>>>       CHECK( "ERROR: could not set the tag data" );
>>>       //create a copy
>>>       iBase_EntityHandle copy;
>>>       iGeom_copyEnt(geom, cyl, &copy, &err);
>>>       CHECK( "ERROR: could not copy the entity" );
>>>       //check to see if the tag is accessible
>>>       int bytes;
>>>       iGeom_getTagSizeBytes(geom, test_tag, &bytes, &err);
>>>       CHECK( "ERROR: could not get the tag size" );
>>>       if (bytes != sizeof(int)) return false;
>>>       iGeom_getIntData(geom, cyl, test_tag, &check_value, &err);
>>>       CHECK( "ERROR: could not get the tag data" );
>>>       if (check_value != value) return false;
>>>       //cleanup
>>>       iGeom_destroyTag(geom, test_tag, 1, &err);
>>>       CHECK( "ERROR: could not destroy tag" );
>>>       iGeom_deleteEnt(geom, cyl, &err);
>>>       CHECK( "ERROR: could not delete entity" );
>>>       iGeom_deleteEnt(geom, copy, &err);
>>>       return true;
>>>     Patrick C. Shriwise
>>>     Research Assistant
>>>     University of Wisconsin - Madison
>>>     Engineering Research Building - Rm. 428
>>>     1500 Engineering Drive
>>>     Madison, WI 53706
>>>     (608) 446-8173
>>     Patrick C. Shriwise
>>     Research Assistant
>>     Madison, WI 53706
>>     (608) 446-8173
>     Patrick C. Shriwise
>     Research Assistant
>     Madison, WI 53706
>     (608) 446-8173
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
Faculty Director, Advanced Computing Infrastructure
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140806/e14bb256/attachment-0001.html>
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140806/e14bb256/attachment-0001.bin>
More information about the cgma-dev mailing list
