[cgma-dev] copying iGeom entities in occ...
    Timothy Tautges
    timothy.tautges at cd-adapco.com
    Tue Aug  5 16:57:44 CDT 2014
Remember, changing the interface will break compatibility with cubit.
Also, this approach looks like flailing without understanding why the
behavior is coded the way it is.  Finally, iGeom should provide an
interface to exactly the same code behavior as CGM functions do, and
modifications meant only to change behavior between cgm vs iGeom interfaces
should not be done.
On Aug 5, 2014 10:13 PM, "Rajeev Jain" <jain at mcs.anl.gov> wrote:
> Hi Patrick,
> Good work.
> How about we make another argument to the copy function?
> With this argument the blue code will be controlled. The argument's
> default will be true -> so nothing changes.
> For your application the argument will be false (don't clear the
> attributes of the copied entities).
> Rajeev
>  *From:* shriwise <shriwise at wisc.edu>
> *To:* "cgma-dev at mcs.anl.gov" <cgma-dev at mcs.anl.gov>
> *Sent:* Tuesday, August 5, 2014 3:49 PM
> *Subject:* Re: [cgma-dev] copying iGeom entities in occ...
>  A little more info. Looks like this problem comes from the finish_copy
> call in GMT. If I comment the lines in blue, my new functions for copying
> tag data from one entity to another work as expected.
> My thought is to add a flags for these functions with regards to copying
> entity tag data/ attribute info. In the GMT functions the default will
> maintain the status quo (do not copy the attribute data) whereas in the
> iGeom interface the default will be to copy the tag/attribute data. Does
> this sound acceptable for now? As of yet this is the only change I will
> need to make outside of the itaps dir in CGM.
> Cheers,
> Patrick
> CubitStatus GeometryModifyTool::finish_copy( TopologyBridge *&new_bridge,
>                                              TopologyBridge *old_bridge )
>   //Remove attributes on underlying entities of virtual geometry
>   //entities which do not have corresponding RefEntities.
>   DLIList<TopologyBridge*> bridge_list;
>   bridge_list.append( old_bridge );
>   GeometryQueryTool::instance()->ige_remove_attributes( bridge_list );
>   //Remove attributes on original entity and children
>   DLIList<RefEntity*> child_list;
>   RefEntity *ref_ent = CAST_TO( old_bridge->topology_entity(), RefEntity
>   ref_ent->get_all_child_ref_entities( child_list );
>   //child_list.append( ref_ent );
>   CubitAttribUser::clear_all_simple_attrib( child_list );
>   child_list.clean_out();
>   //Restore virtual
>   //Could create virtual geometry here so the Topology Bridge can change
>   bridge_list.clean_out();
>   bridge_list.append( new_bridge );
>   TopologyBridge *tmp_bridge_before = new_bridge;
>   GeometryQueryTool::instance()->ige_import_geom( bridge_list );
>   assert( bridge_list.size() == 1 );
>   if( tmp_bridge_before != bridge_list.get() )
>     new_bridge = bridge_list.get();
>   //make the RefEntities
>   Curve *curve = NULL;
>   Surface *surface = NULL;
>   Lump *lump = NULL;
>   BodySM *body = NULL;
>   RefEntity *new_ref_ent = NULL;
>   if( (curve = CAST_TO( new_bridge, Curve ) ) != NULL )
>     new_ref_ent = GeometryQueryTool::instance()->make_RefEdge( curve );
>   else if( (surface = CAST_TO( new_bridge, Surface) ) != NULL )
>     new_ref_ent = GeometryQueryTool::instance()->make_RefFace( surface );
>   else if( (lump = CAST_TO( new_bridge, Lump) ) != NULL )
>     new_ref_ent = GeometryQueryTool::instance()->make_Body( lump->bodysm()
>   else if( (body = CAST_TO( new_bridge, BodySM) ) != NULL )
>     new_ref_ent = GeometryQueryTool::instance()->make_Body( body );
>   //actuate the attributes on everything
>   new_ref_ent->get_all_child_ref_entities( child_list );
>   child_list.append( new_ref_ent );
>   GeometryQueryTool::import_actuate( child_list );
>   //Remove attributes on new entity and children
>   CGMApp::instance()->restore_previous_attribute_states();
>   return CUBIT_SUCCESS;
> On 08/05/2014 03:18 PM, shriwise wrote:
> Just checked and this fails when built w/ CUBIT as well.
> Patrick
> On 08/05/2014 03:13 PM, shriwise wrote:
> Hi all,
> I just ran into an interesting problem in CGM built with OCC. When an
> entity is copied, the original loses all user-applied tag information (or
> so it seems). I understand why a copy might not keep data from the
> original, but for the data to disappear from the original altogether seems
> like incorrect behaviour to me.
> I wrote a test as an example of this below. The test fails on the red
> line. Any ideas as to why? I've tracked the number of tags on the entity
> and they seem to disappear in line 5804 of iGeom_CGMA.cc.
> Any help or insight for this would be very appreciated! I'm close to
> finishing my updates to the iGeom interface and this seems to be the last
> piece of the puzzle.
> bool tag_copied_ent_test(iGeom_Instance geom)
>   int err;
>   //create a tag
>   iBase_TagHandle test_tag;
>   std::string name("test_tag");
>   iGeom_createTag(geom, &name[0], 1, iBase_INTEGER, &test_tag, &err,
> name.length());
>   CHECK( "ERROR: could not create tag" );
>   //create a test entity
>   iBase_EntityHandle cyl;
>   iGeom_createCylinder(geom, 5.0, 5.0, 0.0, &cyl, &err);
>   CHECK( "ERROR: could not create the cylinder" );
>   //set a value for this tag on the original
>   int value = 6;
>   iGeom_setIntData(geom, cyl, test_tag, value, &err);
>   CHECK( "ERROR: could not set the tag data" );
>   //create a copy
>   iBase_EntityHandle copy;
>   iGeom_copyEnt(geom, cyl, ©, &err);
>   CHECK( "ERROR: could not copy the entity" );
>   //check to see if the tag is accessible
>   int bytes;
>   iGeom_getTagSizeBytes(geom, test_tag, &bytes, &err);
>   CHECK( "ERROR: could not get the tag size" );
>   if (bytes != sizeof(int)) return false;
>   iGeom_getIntData(geom, cyl, test_tag, &check_value, &err);
>   CHECK( "ERROR: could not get the tag data" );
>   if (check_value != value) return false;
>   //cleanup
>   iGeom_destroyTag(geom, test_tag, 1, &err);
>   CHECK( "ERROR: could not destroy tag" );
>   iGeom_deleteEnt(geom, cyl, &err);
>   CHECK( "ERROR: could not delete entity" );
>   iGeom_deleteEnt(geom, copy, &err);
>   return true;
> Patrick C. Shriwise
> Research Assistant
> University of Wisconsin - Madison
> Engineering Research Building - Rm. 428
> 1500 Engineering Drive
> Madison, WI 53706
> (608) 446-8173
> Patrick C. Shriwise
> Research Assistant
> Madison, WI 53706
> (608) 446-8173
> Patrick C. Shriwise
> Research Assistant
> Madison, WI 53706
> (608) 446-8173
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140805/32e2c969/attachment.html>
More information about the cgma-dev
