[cgma-dev] commit/CGM: danwu: Removed AM_PROG_AR from CGM's configure.ac (make it similar to MOAB and Lasso). This macro can modify CFLAGS before FATHOM_CHECK_COMPILERS is called, introducing unexpected autoconf defaults (-g -O2) to CFLAGS in the generated Makefile.
Bitbucket commits-noreply at bitbucket.org
Tue Jul 8 13:50:49 CDT 2014
1 new commit in CGM:
https://bitbucket.org/fathomteam/cgm/commits/34e36d8fd9dc/
Changeset:   34e36d8fd9dc
Branch:      master
User:        danwu
Date:        2014-07-08 20:50:12
Summary:     Removed AM_PROG_AR from CGM's configure.ac (make it similar to MOAB and Lasso). This macro can modify CFLAGS before FATHOM_CHECK_COMPILERS is called, introducing unexpected autoconf defaults (-g -O2) to CFLAGS in the generated Makefile.
Affected #:  1 file
Repository URL: https://bitbucket.org/fathomteam/cgm/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
More information about the cgma-dev mailing list
