[cgma-dev] Inconsistency in getEntities for iGeom interface. Causes problems in iRel.
Jane Hu janejhu at gmail.com
Tue Jun 17 09:00:59 CDT 2014
So, I will add RefVolume to the return list
of iGeom_get_adjacent_entities() as the result of the discussion.
CubitEntity only has derived classes of RefEntity
and CubitCoordinateSystem, iGeom_CGMA.cc only uses RefEntity as instance of
the object.
Jane
On Mon, Jun 16, 2014 at 11:35 AM, Jane Hu <janejhu at gmail.com> wrote:
> See comments below...
> On Mon, Jun 16, 2014 at 10:22 AM, Paul Wilson <wilsonp at engr.wisc.edu>
> wrote:
>>  Hi Jane,
>> I think this needs a thorough review!  Patrick and I hunted through
>> iGeom_CGMA and found some inconsistencies in a few places.
>> First, there is an inconsistency between returning pointers to RefEntity
>> and pointers to CubitEntity.  This is probably less important, but should
>> probably be resolved in any change.
> I see RefEntity is inherited from CubitEntity, and CubitEntity is a pure
> virtual class. So even you got pointers to CubitEntity, you have to
> instantiate it to RefEntity objects.
>> Second, there are places where the geometry is queried for entities of
>> dimension=3 (returning RefVolumes) and places where the geometry is queried
>> for entities of type=iGeom_REGION (== Body).
> In this case, I can return both bodies and refvolumes, so after user gets
> the refentity list back, he can cast to see if they are bodies or
> refvolumes, and choose to keep what ever he needs.
>> This means that 2 calls into the interface that should resolve to the
>> same entity may not do so for both reasons.
>> All of this is related to the fundamental difference between the iGeom
>> types (equivalent to vertex, edge, face, volume) and the CGM/ACIS types
>> (equiavlent to vertex, edge, face, volume, body).  I think Tim's suggestion
>> is the best, but will require some substantial effort.
>> Paul
>> On 06/16/2014 10:14 AM, Jane Hu wrote:
>> I see in iGeom_CGMA.cc file, function iGeom_get_adjacent_entities, if
>> asks for 3-D refentities, it returns body list. In CGM, bodies are not
>> necessary to be 3-D entities, it may contain single surface or shell.
>> Should we change the return to be only refvolumes which are 3-D entities (I
>> prefer this, makes more sense)? Or I can return both bodies and refvolumes
>> in the returned refentity list. Depending on your user case, I can return
>> one of the two choices.
>>  Jane
>> On Mon, Jun 16, 2014 at 9:32 AM, Jane Hu <janejhu at gmail.com> wrote:
>>> Yes, it returns a list of refVolume's which are RefEntities.
>>>  Jane
>>> On Sun, Jun 15, 2014 at 11:55 PM, Patrick Shriwise <shriwise at wisc.edu>
>>> wrote:
>>>>  Hi Jane,
>>>>  Will the ref_volumes() method return RefEntities?
>>>>  Patrick
>>>> On Jun 15, 2014, at 3:56 PM, Jane Hu <janejhu at gmail.com> wrote:
>>>>   Look at line 6454, if you have body's pointer, directly call
>>>> ref_volumes() will work. It's not an iGeom interface function, but you can
>>>> access it in iGeom.
>>>>  Good luck!
>>>>  Jane
>>>> On Sat, Jun 14, 2014 at 8:55 AM, Patrick Shriwise <shriwise at wisc.edu>
>>>> wrote:
>>>>>  Hi Jane,
>>>>> I looked around for this but didn't see it, is there a specific
>>>>> line/function you were thinking of? Good to know the ref_volume information
>>>>> is so easy to get to, but it doesn't seem that its part of the iGeom
>>>>> interface. The issue being that there's no way to access a body's volumes
>>>>> via iGeom.
>>>>> Cheers,
>>>>> Patrick
>>>>>  On 06/13/2014 11:26 PM, Jane Hu wrote:
>>>>>>  Is there a way to get volumes within bodies via iGeom?
>>>>>  See example in  iGeom_CGMA.cc, body->ref_volumes(volumes).
>>>>>  Jane
>>>>>> Patrick C. Shriwise
>>>>>> Research Assistant
>>>>>> University of Wisconsin - Madison
>>>>>> Engineering Research Building - Rm. 428
>>>>>> 1500 Engineering Drive
>>>>>> Madison, WI 53706(608) 446-8173
>>>>> Jane Hu
>>>>> Asst. Researcher
>>>>> Dept. of Engineering Physics
>>>>> UW @ Madison
>>>>> "And we know that for those who love God, that is, for those who are
>>>>> called according to his purpose, all things are working together for good."
>>>>> (Romans 8:28)
>>>> Jane Hu
>>>> Asst. Researcher
>>>> UW @ Madison
>>>> (Romans 8:28)
>>> Jane Hu
>>> Asst. Researcher
>>> UW @ Madison
>>> (Romans 8:28)
>> Jane Hu
>> Asst. Researcher
>> UW @ Madison
>> (Romans 8:28)
>> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
>> Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
>> Faculty Director, Advanced Computing Infrastructure
> Jane Hu
> Asst. Researcher
> UW @ Madison
> (Romans 8:28)
Jane Hu
Asst. Researcher
UW @ Madison
"And we know that for those who love God, that is, for those who are called
(Romans 8:28)
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140617/6e62cee5/attachment.html>
More information about the cgma-dev mailing list
