[cgma-dev] Inconsistency in getEntities for iGeom interface. Causes problems in iRel.
Tim Tautges
timothy.tautges at cd-adapco.com
Mon Jun 16 11:56:12 CDT 2014
On 06/16/2014 11:35 AM, Jane Hu wrote:
> See comments below...
> On Mon, Jun 16, 2014 at 10:22 AM, Paul Wilson <wilsonp at engr.wisc.edu <mailto:wilsonp at engr.wisc.edu>> wrote:
> Hi Jane,
> I think this needs a thorough review! Patrick and I hunted through iGeom_CGMA and found some inconsistencies in a
> few places.
> First, there is an inconsistency between returning pointers to RefEntity and pointers to CubitEntity. This is
> probably less important, but should probably be resolved in any change.
> I see RefEntity is inherited from CubitEntity, and CubitEntity is a pure virtual class. So even you got pointers to
> CubitEntity, you have to instantiate it to RefEntity objects.
Be careful with casting here. By the standard, you can return a derived class * as a void* and reassign from void back
to the derived class, but only if the derived class is the same one.
- tim
> Second, there are places where the geometry is queried for entities of dimension=3 (returning RefVolumes) and places
> where the geometry is queried for entities of type=iGeom_REGION (== Body).
> In this case, I can return both bodies and refvolumes, so after user gets the refentity list back, he can cast to see if
> they are bodies or refvolumes, and choose to keep what ever he needs.
> This means that 2 calls into the interface that should resolve to the same entity may not do so for both reasons.
> All of this is related to the fundamental difference between the iGeom types (equivalent to vertex, edge, face,
> volume) and the CGM/ACIS types (equiavlent to vertex, edge, face, volume, body). I think Tim's suggestion is the
> best, but will require some substantial effort.
> Paul
> On 06/16/2014 10:14 AM, Jane Hu wrote:
>> I see in iGeom_CGMA.cc file, function iGeom_get_adjacent_entities, if asks for 3-D refentities, it returns body
>> list. In CGM, bodies are not necessary to be 3-D entities, it may contain single surface or shell. Should we
>> change the return to be only refvolumes which are 3-D entities (I prefer this, makes more sense)? Or I can return
>> both bodies and refvolumes in the returned refentity list. Depending on your user case, I can return one of the
>> two choices.
>> Jane
>> On Mon, Jun 16, 2014 at 9:32 AM, Jane Hu <janejhu at gmail.com <mailto:janejhu at gmail.com>> wrote:
>> Yes, it returns a list of refVolume's which are RefEntities.
>> Jane
>> On Sun, Jun 15, 2014 at 11:55 PM, Patrick Shriwise <shriwise at wisc.edu <mailto:shriwise at wisc.edu>> wrote:
>> Hi Jane,
>> Will the ref_volumes() method return RefEntities?
>> Patrick
>> On Jun 15, 2014, at 3:56 PM, Jane Hu <janejhu at gmail.com <mailto:janejhu at gmail.com>> wrote:
>>> Look at line 6454, if you have body's pointer, directly call ref_volumes() will work. It's not an iGeom
>>> interface function, but you can access it in iGeom.
>>> Good luck!
>>> Jane
>>> On Sat, Jun 14, 2014 at 8:55 AM, Patrick Shriwise <shriwise at wisc.edu <mailto:shriwise at wisc.edu>> wrote:
>>> Hi Jane,
>>> I looked around for this but didn't see it, is there a specific line/function you were thinking of?
>>> Good to know the ref_volume information is so easy to get to, but it doesn't seem that its part of
>>> the iGeom interface. The issue being that there's no way to access a body's volumes via iGeom.
>>> Cheers,
>>> Patrick
>>> On 06/13/2014 11:26 PM, Jane Hu wrote:
>>>> Is there a way to get volumes within bodies via iGeom?
>>>> See example in iGeom_CGMA.cc, body->ref_volumes(volumes).
>>>> Jane
>>>> Patrick C. Shriwise
>>>> Research Assistant
>>>> University of Wisconsin - Madison
>>>> Engineering Research Building - Rm. 428
>>>> 1500 Engineering Drive
>>>> Madison, WI 53706
>>>> (608) 446-8173 <tel:%28608%29%20446-8173>
>>>> Jane Hu
>>>> Asst. Researcher
>>>> Dept. of Engineering Physics
>>>> UW @ Madison
>>>> "And we know that for those who love God, that is, for those who are called according to his
>>>> purpose, all things are working together for good." (Romans 8:28)
>>> Jane Hu
>>> Asst. Researcher
>>> UW @ Madison
>>> "And we know that for those who love God, that is, for those who are called according to his purpose, all
>> Jane Hu
>> Asst. Researcher
>> UW @ Madison
>> Jane Hu
>> Asst. Researcher
>> UW @ Madison
>> "And we know that for those who love God, that is, for those who are called according to his purpose, all things
> Paul Wilson ~ UW-Madison ~608-263-0807 <tel:608-263-0807> ~ cal:http://bit.ly/pphw-cal
> Professor, Engineering Physics. ~http://cnerg.engr.wisc.edu
> Faculty Director, Advanced Computing Infrastructure
> Jane Hu
> Asst. Researcher
> UW @ Madison
> "And we know that for those who love God, that is, for those who are called according to his purpose, all things are
Timothy J. Tautges
Manager, Directed Meshing, CD-adapco
Phone: 608-354-1459
More information about the cgma-dev
