[cgma-dev] commit/CGM: Jane Hu: In an effort to find the example for oce patches, found that the edges' order in the modify.cpp testcases changed, hence added a check to use the particular edge for testing sweep_translational. Passed modify test.
Bitbucket
commits-noreply at bitbucket.org
Fri Jun 13 12:46:53 CDT 2014
1 new commit in CGM:
https://bitbucket.org/fathomteam/cgm/commits/20be5ee0426b/
Changeset: 20be5ee0426b
Branch: cgm13.1
User: Jane Hu
Date: 2014-06-13 19:44:12
Summary: In an effort to find the example for oce patches, found that the edges' order in the modify.cpp testcases changed, hence added a check to use the particular edge for testing sweep_translational. Passed modify test.
Affected #: 1 file
Repository URL: https://bitbucket.org/fathomteam/cgm/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
More information about the cgma-dev
