[cgma-dev] CGM failing with OCC6.6.0
Grindeanu, Iulian R.
iulian at mcs.anl.gov
Thu Apr 10 13:49:09 CDT 2014
Ouch :(
Buildbot was testing only cgm13.1 against occ660. If cgm master fails (I think it is 14.0), it means Jane would have to look at it.
Does anybody build cgm master with occ 660?
Iulian
From: cgma-dev-bounces at mcs.anl.gov [cgma-dev-bounces at mcs.anl.gov] on behalf of Paul Wilson [wilsonp at engr.wisc.edu]
Sent: Thursday, April 10, 2014 12:23 PM
To: CGMA Development
Subject: [cgma-dev] CGM failing with OCC6.6.0
Hello all,
I thought I had overcome these problems last month, but I seem to be
having new problems.
I have successfully built CGM13.1 with OCC 6.6.0, including successful
testing with 'make check'.
When I use the identical installation of OCC 6.6.0 to build the master
CGM branch (14.1?) it fails on 'make check'. I have looked and the
patch to OCC 6.6.0 didn't change between CGM13.1 and master. It
certainly seems that the code did change.
Any tips?
Paul
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
Faculty Director, Advanced Computing Infrastructure
More information about the cgma-dev
