[cgma-dev] CGM failing with OCC6.6.0
Paul Wilson wilsonp at engr.wisc.edu
Thu Apr 10 12:23:25 CDT 2014
Hello all,
I thought I had overcome these problems last month, but I seem to be
having new problems.
I have successfully built CGM13.1 with OCC 6.6.0, including successful
testing with 'make check'.
When I use the identical installation of OCC 6.6.0 to build the master
CGM branch (14.1?) it fails on 'make check'.  I have looked and the
patch to OCC 6.6.0 didn't change between CGM13.1 and master.  It
certainly seems that the code did change.
Any tips?
Paul
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
Faculty Director, Advanced Computing Infrastructure
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140410/5fd73f4b/attachment.bin>
More information about the cgma-dev mailing list
