[cgma-dev] [MOAB-dev] OCC CGM testing
Paul Wilson
wilsonp at engr.wisc.edu
Tue Mar 25 13:20:28 CDT 2014
Success!!!
With some help from Jane, I was able to determine that it was missing
dependencies for OCC that were causing the problem, namely FreeType.
I think it is very important to note: OCC will identify missing
dependencies during configure, but will STILL build successfully and not
report any other errors. OCC doesn't actually do anything with "make
check" so there is not way to know.
In my case, there was a note during configure on missing "Mandatory"
dependencies, but it build successfully and even allowed me to build CGM
successfully.
Paul
On 03/25/2014 11:00 AM, Grindeanu, Iulian R. wrote:
> did you build occ shared or static?
> We build here shared
> And then we set
> LD_LIBRARY_PATH=/homes/fathom/3rdparty/occ/OpenCASCADE6.6.0/gccGnep/lib
> also, the build uses cgm13.1 branch
> gnep/disks/itaps-buildslave/cgm131-occ660/build> git branch
> * cgm13.1
> It looks like you have a missing file.
> Iulian
> From: Paul Wilson [wilsonp at engr.wisc.edu]
> Sent: Tuesday, March 25, 2014 10:49 AM
> To: Grindeanu, Iulian R.; Patrick Shriwise; MOAB-dev at mcs.anl.gov; CGMA Development
> Subject: Re: [MOAB-dev] OCC CGM testing
> Hi again,
> just looked at gnep and confirmed that make check is occurring.
> Here is my config: ../configure
> --with-occ=/home/wilsonp/.local/OCC/6.6.0_patched
> --prefix=/home/wilsonp/.local/cgm/13.1.1_occ660
> Make check log: make_check_log
> Errors are attached as: make_check_err
> The errors are all in iTaps, so I included: test-suite.log
> I'll also try to sit with Jane to look at these.
> Paul
> On 03/25/2014 10:40 AM, Paul Wilson wrote:
>> Hi Iulian,
>> [Adding CGM mailing list]
>> Do you run 'make check' on buildbot? I did a clean build of OCC6.6.0
>> and CGM13.1.1 and it built successfully but failed on 'make check'.
>> Paul
>> On 03/25/2014 07:11 AM, Grindeanu, Iulian R. wrote:
>>> hello,
>>> I built occ 6.6.0 on gnep.mcs, and cgm 13.1 configured with it
>>> worked fine last night
>>> http://gnep.mcs.anl.gov:8010/builders/cgm131-occ660
>>> On mcs network, occ 660 is installed at:
>>> I will update instructions on
>>> http://trac.mcs.anl.gov/projects/ITAPS/wiki/BuildingOcc65
>>> Jane, will all cgm branches work against occ 660?
>>> (I am pretty sure master branch will work, I don't know about cgm12.2)
>>> Iulian
>>> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on
>>> behalf of Grindeanu, Iulian R. [iulian at mcs.anl.gov]
>>> Sent: Monday, March 24, 2014 10:48 AM
>>> To: Paul Wilson; Patrick Shriwise; MOAB-dev at mcs.anl.gov
>>> Hi Paul,
>>> occ 653 was built on gnep.mcs.anl.gov. It is not built every night,
>>> as part of buildbot. gnep is at ubuntu 10.04, but I did built it on
>>> my laptop successfully, too, which is 12.04
>>> Maybe I don't understand the question.
>>> What kind of instructions? Maybe they are not up-to-date. Or the
>>> patch fails to be applied ?
>>> Iulian
>>> Sent: Monday, March 24, 2014 10:05 AM
>>> Hi Iulian,
>>> I was unsuccessful in following the instructions for building OCC653
>>> with the provided patch. (Note: the instructions didn't work perfectly
>>> either, but that's a different issue).
>>> Can you provide the script or automated instructions that are used to
>>> build this on buildbot?
>>> Paul
>>> On 03/21/2014 10:09 AM, Grindeanu, Iulian R. wrote:
>>>> http://gnep.mcs.anl.gov:8010/waterfall?category=cgm
>>>> any build that contains occ in its name is built with occ653
>>>> We actually test on cgm13.1 too, on buildbot
>>>> "trunk", "tr", "tru" means current cgm master repo (former trunk on
>>>> svn)
>>>> the others are with cgm branch cgm12.2
>>>> Sent: Thursday, March 20, 2014 3:59 PM
>>>> To: Patrick Shriwise; MOAB-dev at mcs.anl.gov
>>>> occ 653 with cgm master, and occ 653 with cgm branch cgm12.2 (serial
>>>> and parallel)
>>>> we used to test with cgm13.1 branch, too, but it should be fine
>>>> Iulian
>>>> behalf of Patrick Shriwise [shriwise at wisc.edu]
>>>> Sent: Thursday, March 20, 2014 1:52 PM
>>>> To: MOAB-dev at mcs.anl.gov
>>>> Subject: [MOAB-dev] OCC CGM testing
>>>> Hi all,
>>>> What version(s) of OCC and CGM are tested in the MOAB nightlies?
>>>> Going to create a similar set of builds for testing on my local
>>>> machine.
>>>> Thanks!
>>>> Patrick C. Shriwise
>>>> Research Assistant
>>>> University of Wisconsin - Madison
>>>> Engineering Research Building - Rm. 428
>>>> 1500 Engineering Drive
>>>> Madison, WI 53706
>>>> (608) 446-8173
>>> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
>>> Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
>>> Faculty Director, Advanced Computing Infrastructure
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20140325/d5ec8986/attachment.bin>
More information about the cgma-dev
