[cgma-dev] [MOAB-dev] OCC CGM testing
    Grindeanu, Iulian R.
    iulian at mcs.anl.gov
    Tue Mar 25 11:00:31 CDT 2014
did you build occ shared or static?
We build here shared
And then we set
LD_LIBRARY_PATH=/homes/fathom/3rdparty/occ/OpenCASCADE6.6.0/gccGnep/lib
also, the build uses cgm13.1 branch
gnep/disks/itaps-buildslave/cgm131-occ660/build> git branch
* cgm13.1
It looks like you have a missing file.
Iulian
Sent: Tuesday, March 25, 2014 10:49 AM
To: Grindeanu, Iulian R.; Patrick Shriwise; MOAB-dev at mcs.anl.gov; CGMA Development
Subject: Re: [MOAB-dev] OCC CGM testing
Hi again,
just looked at gnep and confirmed that make check is occurring.
Here is my config:  ../configure
--with-occ=/home/wilsonp/.local/OCC/6.6.0_patched
--prefix=/home/wilsonp/.local/cgm/13.1.1_occ660
Make check log: make_check_log
Errors are attached as: make_check_err
The errors are all in iTaps, so I included: test-suite.log
I'll also try to sit with Jane to look at these.
Paul
On 03/25/2014 10:40 AM, Paul Wilson wrote:
> Hi Iulian,
> [Adding CGM mailing list]
> Do you run 'make check' on buildbot?  I did a clean build of OCC6.6.0
> and CGM13.1.1 and it built successfully but failed on 'make check'.
> Paul
> On 03/25/2014 07:11 AM, Grindeanu, Iulian R. wrote:
>> hello,
>>   I built occ 6.6.0 on gnep.mcs, and cgm 13.1 configured with it
>> worked fine last night
>> http://gnep.mcs.anl.gov:8010/builders/cgm131-occ660
>> On mcs network, occ 660 is installed at:
>> I will update instructions on
>> http://trac.mcs.anl.gov/projects/ITAPS/wiki/BuildingOcc65
>> Jane, will all cgm branches work against occ 660?
>> (I am pretty sure master branch will work, I don't know about cgm12.2)
>> Iulian
>> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on
>> behalf of Grindeanu, Iulian R. [iulian at mcs.anl.gov]
>> Sent: Monday, March 24, 2014 10:48 AM
>> To: Paul Wilson; Patrick Shriwise; MOAB-dev at mcs.anl.gov
>> Hi Paul,
>> occ 653 was built on gnep.mcs.anl.gov. It is not built every night,
>> as part of buildbot. gnep is at ubuntu 10.04, but I did built it on
>> my laptop successfully, too, which is 12.04
>> Maybe I don't understand the question.
>> What kind of instructions? Maybe they are not up-to-date. Or the
>> patch fails to be applied ?
>> Iulian
>> From: Paul Wilson [wilsonp at engr.wisc.edu]
>> Sent: Monday, March 24, 2014 10:05 AM
>> Hi Iulian,
>> I was unsuccessful in following the instructions for building OCC653
>> with the provided patch. (Note: the instructions didn't work perfectly
>> either, but that's a different issue).
>> Can you provide the script or automated instructions that are used to
>> build this on buildbot?
>> Paul
>> On 03/21/2014 10:09 AM, Grindeanu, Iulian R. wrote:
>>> http://gnep.mcs.anl.gov:8010/waterfall?category=cgm
>>> any build that contains occ in its name is built with occ653
>>> We actually test on cgm13.1 too, on buildbot
>>> "trunk", "tr", "tru" means current cgm master repo (former trunk on
>>> svn)
>>> the others are with cgm branch cgm12.2
>>> Sent: Thursday, March 20, 2014 3:59 PM
>>> To: Patrick Shriwise; MOAB-dev at mcs.anl.gov
>>> occ 653 with cgm master, and occ 653 with cgm branch cgm12.2 (serial
>>> and parallel)
>>> we used to test with cgm13.1 branch, too, but it should be fine
>>> Iulian
>>> behalf of Patrick Shriwise [shriwise at wisc.edu]
>>> Sent: Thursday, March 20, 2014 1:52 PM
>>> To: MOAB-dev at mcs.anl.gov
>>> Subject: [MOAB-dev] OCC CGM testing
>>> Hi all,
>>> What version(s) of OCC and CGM are tested in the MOAB nightlies?
>>> Going to create a similar set of builds for testing on my local
>>> machine.
>>> Thanks!
>>> Patrick C. Shriwise
>>> Research Assistant
>>> University of Wisconsin - Madison
>>> Engineering Research Building - Rm. 428
>>> 1500 Engineering Drive
>>> Madison, WI 53706
>>> (608) 446-8173
>> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
>> Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
>> Faculty Director, Advanced Computing Infrastructure
More information about the cgma-dev
