[cgma-dev] CMake build system
David Thompson david.thompson at kitware.com
Tue Jan 21 10:49:47 CST 2014
Hi all,
Now that I can build the most modern cgm on my machine, I see that some subdirectories of CGM now have CMakeLists.txt files -- each creating a separate project, and with no toplevel project. When I add a toplevel project, it does not quite build. When I fix it so things compile, there is no libcgm created; instead a separate library exists for each subdirectory (I guess autoconf builds libcgm from these "convenience libraries"?).
Are the CMake files work in progress or remnants that have been abandoned?
	David
More information about the cgma-dev mailing list
