[cgma-dev] Missing include on Mavericks (+patch)
Jane Hu janejhu at gmail.com
Mon Dec 2 15:33:56 CST 2013
Current trunk is only buildable with occ, there's a bug which prevent cubit
build on cgm14.0 and I am working on it.
I haven't seen your error yet, it seems to be a machine specific one. We
only tested cgm build on Linux, maybe also on Windows? But not other
machine yet. Please let us know when you figured out the cause.
Jane
On Mon, Dec 2, 2013 at 3:08 PM, David Thompson
<david.thompson at kitware.com>wrote:
> Hi Jane,
> > It's just been done. Happy coding!
> Thanks! However, when I updated to catch this fix, I ran into another
> issue:
> libtool: compile:  clang++ -I. -I/Users/dcthomp/Source/cgm/geom -I..
> -I../geom/parallel -I../itaps -I/Users/dcthomp/Source/cgm/util -I. -g -Wall
> -mmacosx-version-min=10.9
> --sysroot=/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.9.sdk
> -arch x86_64 -Wall -pipe -pedantic -MT CubitAttribManager.lo -MD -MP -MF
> .deps/CubitAttribManager.Tpo -c
> /Users/dcthomp/Source/cgm/geom/CubitAttribManager.cpp  -fno-common -DPIC -o
> .libs/CubitAttribManager.o
> /Users/dcthomp/Source/cgm/geom/CubitAttribManager.cpp:108:28: error: no
> viable conversion from 'CubitBoolean' (aka 'bool') to
>       'const_reference' (aka '__bit_const_reference<std::__1::vector<bool,
> std::__1::allocator<bool> > >')
>   mAutoActuateFlags.append(auto_actuate_flag);
> /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/c++/v1/__bit_reference:124:7:
> note:
>       candidate constructor (the implicit copy constructor) not viable: no
> known conversion from 'CubitBoolean' (aka 'bool') to
>       'const std::__1::__bit_const_reference<std::__1::vector<bool,
> std::__1::allocator<bool> > > &' for 1st argument
> class __bit_const_reference
> /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/c++/v1/__bit_reference:140:5:
> note:
>       candidate constructor not viable: no known conversion from
> 'CubitBoolean' (aka 'bool') to 'const
>       __bit_reference<std::__1::vector<bool, std::__1::allocator<bool> > >
> &' for 1st argument
>     __bit_const_reference(const __bit_reference<_Cp>& __x) _NOEXCEPT
> /Users/dcthomp/Source/cgm/util/DLIList.hpp:448:31: note: passing argument
> to parameter 'new_item' here
>   void append(const_reference new_item);
> I haven't been able to figure out the source of this problem. Both Apple's
> new C++ library and the old GNU one specialize vector<bool>, so that does
> not appear to be the cause. If it helps, I had not updated since before you
> moved the cubit-14 branch to the trunk.
>         David
> > On Mon, Dec 2, 2013 at 12:43 PM, David Thompson <
> david.thompson at kitware.com> wrote:
> > Hi all,
> > When I try building on OS X Mavericks using the latest Xcode, I get an
> error that pid_t is not defined in util/CubitProcess.h. It appears that
> <unistd.h> must be included for this type to be defined. A patch is below.
> Could someone apply it or help me revise it so I can build without patching
> CGM?
> >         Thanks,
> >         David
> > --- a/util/CubitProcess.hpp
> > +++ b/util/CubitProcess.hpp
> > @@ -20,6 +20,7 @@
> >  #include <windows.h>
> >  typedef PROCESS_INFORMATION PidType;
> >  #else
> > +#  include <unistd.h>
> >  typedef pid_t PidType;
> >  #endif
> > Jane Hu
> > Asst. Researcher
> > Dept. of Engineering Physics
> > UW @ Madison
> > "And we know that for those who love God, that is, for those who are
> called according to his purpose, all things are working together for good."
> (Romans 8:28)
Jane Hu
Asst. Researcher
UW @ Madison
"And we know that for those who love God, that is, for those who are called
(Romans 8:28)
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20131202/87e730d5/attachment-0001.html>
More information about the cgma-dev mailing list
