[cgma-dev] Missing include on Mavericks (+patch)
    David Thompson
    david.thompson at kitware.com
    Mon Dec  2 15:08:02 CST 2013
Hi Jane,
> It's just been done. Happy coding!
Thanks! However, when I updated to catch this fix, I ran into another issue:
libtool: compile:  clang++ -I. -I/Users/dcthomp/Source/cgm/geom -I.. -I../geom/parallel -I../itaps -I/Users/dcthomp/Source/cgm/util -I. -g -Wall -mmacosx-version-min=10.9 --sysroot=/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.9.sdk -arch x86_64 -Wall -pipe -pedantic -MT CubitAttribManager.lo -MD -MP -MF .deps/CubitAttribManager.Tpo -c /Users/dcthomp/Source/cgm/geom/CubitAttribManager.cpp  -fno-common -DPIC -o .libs/CubitAttribManager.o
/Users/dcthomp/Source/cgm/geom/CubitAttribManager.cpp:108:28: error: no viable conversion from 'CubitBoolean' (aka 'bool') to
      'const_reference' (aka '__bit_const_reference<std::__1::vector<bool, std::__1::allocator<bool> > >')
  mAutoActuateFlags.append(auto_actuate_flag);
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/c++/v1/__bit_reference:124:7: note:
      candidate constructor (the implicit copy constructor) not viable: no known conversion from 'CubitBoolean' (aka 'bool') to
      'const std::__1::__bit_const_reference<std::__1::vector<bool, std::__1::allocator<bool> > > &' for 1st argument
class __bit_const_reference
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/c++/v1/__bit_reference:140:5: note:
      candidate constructor not viable: no known conversion from 'CubitBoolean' (aka 'bool') to 'const
      __bit_reference<std::__1::vector<bool, std::__1::allocator<bool> > > &' for 1st argument
    __bit_const_reference(const __bit_reference<_Cp>& __x) _NOEXCEPT
/Users/dcthomp/Source/cgm/util/DLIList.hpp:448:31: note: passing argument to parameter 'new_item' here
  void append(const_reference new_item);
I haven't been able to figure out the source of this problem. Both Apple's new C++ library and the old GNU one specialize vector<bool>, so that does not appear to be the cause. If it helps, I had not updated since before you moved the cubit-14 branch to the trunk.
	David
> On Mon, Dec 2, 2013 at 12:43 PM, David Thompson <david.thompson at kitware.com> wrote:
> Hi all,
> When I try building on OS X Mavericks using the latest Xcode, I get an error that pid_t is not defined in util/CubitProcess.h. It appears that <unistd.h> must be included for this type to be defined. A patch is below. Could someone apply it or help me revise it so I can build without patching CGM?
>         Thanks,
>         David
> --- a/util/CubitProcess.hpp
> +++ b/util/CubitProcess.hpp
> @@ -20,6 +20,7 @@
>  #include <windows.h>
>  typedef PROCESS_INFORMATION PidType;
>  #else
> +#  include <unistd.h>
>  typedef pid_t PidType;
>  #endif
> Jane Hu
> Asst. Researcher
> Dept. of Engineering Physics
> UW @ Madison
> "And we know that for those who love God, that is, for those who are called according to his purpose, all things are working together for good." (Romans 8:28)
More information about the cgma-dev
