[cgma-dev] iGeom::reflectEnt signature
Paul Wilson
wilsonp at engr.wisc.edu
Fri Nov 22 11:58:17 CST 2013
Hi Jane,
That's just the info I needed. Thanks!
Paul
On 11/22/2013 10:43 AM, Jane Hu wrote:
> Hi, Paul:
> This change is due to cubit change from 12.2 to 13.1. Before it was
> assumed to reflect against a plane crossing origin, and now it allows
> to reflect any plane crossing any given point with any given plane
> direction.
> You just need to give the point as (0,0,0) to let the previous passed
> tests to run against cgm13.1 and above.
> Hope it helps.
> Jane
> On Thu, Nov 21, 2013 at 4:30 PM, Paul Wilson <wilsonp at engr.wisc.edu
> <mailto:wilsonp at engr.wisc.edu>> wrote:
> Hi there,
> I'm trying to build a tool that used to work against CGM using the
> iGeom interface. It uses the reflectEnt method.
> As of r5781, the reflectEnt signature in iGeom.h has changed to
> require 2 sets of x,y,z points, but the documentation is not clear
> about what these mean. I'm happy to update my app to this new
> signature but can't find a definition of what is expected.
> 3402 jvporter /**\brief Reflect an entity across a plane
> 3402 jvporter *
> 3402 jvporter * Reflect an entity across the given plane
> 3402 jvporter * \param instance iGeom instance handle
> 3402 jvporter * \param geom_entity the entity to reflect
> 3402 jvporter * \param plane_normal_x x coordinate of
> the plane's normal
> 3402 jvporter * \param plane_normal_y y coordinate of
> the plane's normal
> 3402 jvporter * \param plane_normal_z z coordinate of
> the plane's normal
> 3402 jvporter * \param *err Pointer to error type
> returned from function
> 3402 jvporter */
> 3402 jvporter void iGeom_reflectEnt( iGeom_Instance
> instance,
> 2617 kraftche iBase_EntityHandle geom_entity,
> 5781 janehu double point_x,
> 5781 janehu double point_y,
> 5781 janehu double point_z,
> 1638 tautges double plane_normal_x,
> 1638 tautges double plane_normal_y,
> 1638 tautges double plane_normal_z,
> 1638 tautges int* err );
> 1096 kraftche
> Any guidance is appreciated.
> Thanks,
> Paul
> Paul Wilson ~ UW-Madison ~ 608-263-0807 <tel:608-263-0807> ~ cal:
> http://bit.ly/pphw-cal
> Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
> Faculty Director, Advanced Computing Infrastructure
> Jane Hu
> Asst. Researcher
> Dept. of Engineering Physics
> UW @ Madison
> "And we know that for those who love God, that is, for those who are
> called according to his purpose, all things are working together for
> good." (Romans 8:28)
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20131122/72f648ca/attachment.html>
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20131122/72f648ca/attachment.bin>
More information about the cgma-dev
