[cgma-dev] iGeom::reflectEnt signature
Jane Hu janejhu at gmail.com
Fri Nov 22 10:43:03 CST 2013
Hi, Paul:
This change is due to cubit change from 12.2 to 13.1. Before it was assumed
to reflect against a plane crossing origin, and now it allows to reflect
any plane crossing any given point with any given plane direction.
You just need to give the point as (0,0,0) to let the previous passed tests
to run against cgm13.1 and above.
Hope it helps.
Jane
On Thu, Nov 21, 2013 at 4:30 PM, Paul Wilson <wilsonp at engr.wisc.edu> wrote:
> Hi there,
> I'm trying to build a tool that used to work against CGM using the iGeom
> interface.  It uses the reflectEnt method.
> As of r5781, the reflectEnt signature in iGeom.h has changed to require 2
> sets of x,y,z points, but the documentation is not clear about what these
> mean.  I'm happy to update my app to this new signature but can't find a
> definition of what is expected.
>    3402   jvporter    /**\brief  Reflect an entity across a plane
>>   3402   jvporter      *
>>   3402   jvporter      * Reflect an entity across the given plane
>>   3402   jvporter      * \param instance iGeom instance handle
>>   3402   jvporter      * \param geom_entity the entity to reflect
>>   3402   jvporter      * \param plane_normal_x x coordinate of the
>> plane's normal
>>   3402   jvporter      * \param plane_normal_y y coordinate of the
>> plane's normal
>>   3402   jvporter      * \param plane_normal_z z coordinate of the
>> plane's normal
>>   3402   jvporter      * \param *err Pointer to error type returned from
>> function
>>   3402   jvporter      */
>>   3402   jvporter   void iGeom_reflectEnt( iGeom_Instance instance,
>>   2617   kraftche                          iBase_EntityHandle geom_entity,
>>   5781     janehu                          double point_x,
>>   5781     janehu                          double point_y,
>>   5781     janehu                          double point_z,
>>   1638    tautges                          double plane_normal_x,
>>   1638    tautges                          double plane_normal_y,
>>   1638    tautges                          double plane_normal_z,
>>   1638    tautges                          int* err );
>>   1096   kraftche
> Any guidance is appreciated.
> Thanks,
> Paul
> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
> Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
> Faculty Director, Advanced Computing Infrastructure
Jane Hu
Asst. Researcher
Dept. of Engineering Physics
UW @ Madison
"And we know that for those who love God, that is, for those who are called
according to his purpose, all things are working together for good."
(Romans 8:28)
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20131122/67d758b6/attachment-0001.html>
More information about the cgma-dev mailing list
