[cgma-dev] CGMA with Cubit not reading ACIS files
David Thompson
david.thompson at kitware.com
Thu Aug 1 15:04:14 CDT 2013
Hi Jane,
> After we changed to cubit13.1 in truck, we support interface defined in CubitCompat.hpp, which is CubitCompat_import_solid_model. Can you try this out and let us know if it works?
Yup, that works!
Will CubitCompat_import_solid_model also work for other engines (OCC, Cholla/facet/facetbool) or is it just for the Cubit engine?
David
> On Wed, Jul 31, 2013 at 5:39 PM, David Thompson <david.thompson at kitware.com> wrote:
> Hi Iulian,
> > We are building usually on linux only; ...
> The software we're working on needs to support the big 3 (Linux, OS X, Windows).
> > Rajeev is building on 64 bit OSx, but only with occ.
> > Does it pass make check for you or not?
> Yes. I have to fiddle with DYLD_LIBRARY_PATH because of the way Cubit is prepared on OS X, but make check passes.
> Thanks,
> David
> > > You cannot configure with cubit and occ at the same time.
> > I did not.
> > > What is your configuration ?
> > CXX=clang++ CC=clang CXXFLAGS="-arch i386" CFLAGS="-arch i386" /path/to/cgm/configure --prefix=/path/to/cgm/x86_install --enable-shared --with-cubit=/Applications/Cubit-13.1/Cubit.app/Contents/MacOS
> > Thanks,
> > David
> > > Hi all,
> > > I have a version of CGMA working with OCC but when I build with cubit support, some simple test programs I wrote don't work any longer. Specifically, calling
> > > const char* filename = "/path/to/cgm/test/model1.sat";
> > > ModelImportOptions opts;
> > > DLIList<RefEntity*> entities;
> > > stat = GeometryQueryTool::instance()->import_solid_model(
> > > filename, ACIS_SAT_TYPE, opts, entities);
> > > returns CUBIT_SUCCESS and prints a non-zero number of "ACIS Entities" have been read but then
> > > 1. entities is an empty list and
> > > 2. calling GeometryQueryTool::instance()->bodies() also returns an empty list.
> > > Has anyone else seen this problem?
> > > Thanks,
> > > David
> Jane Hu
> Asst. Researcher
> Dept. of Engineering Physics
> UW @ Madison
> "And we know that for those who love God, that is, for those who are called according to his purpose, all things are working together for good." (Romans 8:28)
More information about the cgma-dev
