[cgma-dev] Fwd: r6032 - in	cgm/branches/merge-cubit12:	cgm_apps/examples/facetdriver	geom/testing
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Fri Mar 15 18:18:34 CDT 2013
Sorry about these commits;
the commit message was about merge-cubit12.2, while in fact I was on cubit-merge12 branch.
It will not hurt cubit-merge12 branch though;
although this one should be discontinued; and it confused me because its name was very close to cubit-merge12.2 .
Best Regards,
Iulian
----- Forwarded Message -----
To: cgma-dev at mcs.anl.gov
Sent: Friday, March 15, 2013 4:33:06 PM
Subject: [cgma-dev] r6032 - in cgm/branches/merge-cubit12: cgm_apps/examples/facetdriver geom/testing
Author: iulian
Date: 2013-03-15 16:33:05 -0500 (Fri, 15 Mar 2013)
New Revision: 6032
Modified:
cgm/branches/merge-cubit12/cgm_apps/examples/facetdriver/Makefile.am
cgm/branches/merge-cubit12/geom/testing/Makefile.am
Log:
forgot these two changes at the previous commit
on mergecubit12.2 branch, shared build, we need this for ubuntu 12.04
(because of golden linker rule, dependent libraries need to be explicit)
Modified: cgm/branches/merge-cubit12/cgm_apps/examples/facetdriver/Makefile.am
--- cgm/branches/merge-cubit12/cgm_apps/examples/facetdriver/Makefile.am 2013-03-15 21:00:25 UTC (rev 6031)
+++ cgm/branches/merge-cubit12/cgm_apps/examples/facetdriver/Makefile.am 2013-03-15 21:33:05 UTC (rev 6032)
@@ -11,4 +11,4 @@
-I$(top_srcdir)/geom/Cholla \
-I$(top_srcdir)/geom/facet
-LDADD = $(top_builddir)/libcgm.la $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS)
+LDADD = $(top_builddir)/libcgm.la $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS) $(CGM_EXT_LIBS)
Modified: cgm/branches/merge-cubit12/geom/testing/Makefile.am
--- cgm/branches/merge-cubit12/geom/testing/Makefile.am 2013-03-15 21:00:25 UTC (rev 6031)
+++ cgm/branches/merge-cubit12/geom/testing/Makefile.am 2013-03-15 21:33:05 UTC (rev 6032)
@@ -14,7 +14,7 @@
endif
AM_CPPFLAGS += -I$(top_srcdir)/util -I$(top_srcdir)/geom -I.
-LDADD = libcgm_test.la ../../libcgm.la $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS)
+LDADD = libcgm_test.la ../../libcgm.la $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS) $(CGM_EXT_LIBS)
SUFFIXES = .acis .occ
check_PROGRAMS = $(BASE_TESTS:.engine=)
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20130315/ecd704b7/attachment.html>
More information about the cgma-dev
