[cgma-dev] r6032 - in cgm/branches/merge-cubit12:	cgm_apps/examples/facetdriver geom/testing
    iulian at mcs.anl.gov
    Fri Mar 15 16:33:06 CDT 2013
Author: iulian
Date: 2013-03-15 16:33:05 -0500 (Fri, 15 Mar 2013)
New Revision: 6032
Modified:
   cgm/branches/merge-cubit12/cgm_apps/examples/facetdriver/Makefile.am
   cgm/branches/merge-cubit12/geom/testing/Makefile.am
Log:
forgot these two changes at the previous commit
on mergecubit12.2 branch, shared build, we need this for ubuntu 12.04
(because of golden linker rule, dependent libraries need to be explicit)
Modified: cgm/branches/merge-cubit12/cgm_apps/examples/facetdriver/Makefile.am
--- cgm/branches/merge-cubit12/cgm_apps/examples/facetdriver/Makefile.am	2013-03-15 21:00:25 UTC (rev 6031)
+++ cgm/branches/merge-cubit12/cgm_apps/examples/facetdriver/Makefile.am	2013-03-15 21:33:05 UTC (rev 6032)
@@ -11,4 +11,4 @@
                -I$(top_srcdir)/geom/Cholla \
                -I$(top_srcdir)/geom/facet
-LDADD = $(top_builddir)/libcgm.la $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS)
+LDADD = $(top_builddir)/libcgm.la $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS) $(CGM_EXT_LIBS)
Modified: cgm/branches/merge-cubit12/geom/testing/Makefile.am
--- cgm/branches/merge-cubit12/geom/testing/Makefile.am	2013-03-15 21:00:25 UTC (rev 6031)
+++ cgm/branches/merge-cubit12/geom/testing/Makefile.am	2013-03-15 21:33:05 UTC (rev 6032)
@@ -14,7 +14,7 @@
 endif
 AM_CPPFLAGS += -I$(top_srcdir)/util -I$(top_srcdir)/geom -I.
-LDADD = libcgm_test.la ../../libcgm.la  $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS)
+LDADD = libcgm_test.la ../../libcgm.la  $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS) $(CGM_EXT_LIBS)
 SUFFIXES = .acis .occ
 check_PROGRAMS = $(BASE_TESTS:.engine=)
More information about the cgma-dev
