[cgma-dev] r5884 - cgm/trunk/util
janehu at mcs.anl.gov
Mon Nov 26 11:48:07 CST 2012
Author: janehu
Date: 2012-11-26 11:48:07 -0600 (Mon, 26 Nov 2012)
New Revision: 5884
Added:
cgm/trunk/util/CubitInstrumentation.cpp
cgm/trunk/util/CubitProcess.cpp
cgm/trunk/util/CubitProcess.hpp
cgm/trunk/util/GlobalCommandFeedback.cpp
cgm/trunk/util/GlobalCommandFeedback.hpp
cgm/trunk/util/ManagedPtrVector.hpp
Modified:
cgm/trunk/util/Makefile.am
Log:
Added files in Makefile.am for make check after install, still there's one testcase failing in itaps and test directory each, and seems to be the same problem. Still looking into it.
Copied: cgm/trunk/util/CubitInstrumentation.cpp (from rev 5883, cgm/branches/cubit13.1/util/CubitInstrumentation.cpp)
--- cgm/trunk/util/CubitInstrumentation.cpp (rev 0)
+++ cgm/trunk/util/CubitInstrumentation.cpp 2012-11-26 17:48:07 UTC (rev 5884)
@@ -0,0 +1,221 @@
+// File: CubitInstrumentation.cpp
+// Author: Boyd Tidwell
+// Purpose: CubitInstrumentation is used to collect and write command and
+// feature usage by Cubit users.
+#include "CubitInstrumentation.hpp"
+#include "CubitMessage.hpp"
+//#include <iostream>
+CubitInstrumentation* CubitInstrumentation::thisInstance = NULL;
+CubitInstrumentation* CubitInstrumentation::instance()
+ if (!thisInstance)
+ thisInstance = new CubitInstrumentation;
+ PRINT_ERROR("Unable to instantiate instrumentation object!\n");
+ exit(1);
+ return thisInstance;
+void CubitInstrumentation::delete_instance()
+ if (thisInstance)
+ delete thisInstance;
+ thisInstance = NULL;
+CubitInstrumentation::CubitInstrumentation()
+ : outputState(Unknown),
+ recordTokens(true), validKeywords(false), writeKeywords(true),
+ tokenUsageStream(NULL)
More information about the cgma-dev
