[cgma-dev] r5883 - cgm/trunk
    janehu at mcs.anl.gov
    Mon Nov 26 09:48:43 CST 2012
Author: janehu
Date: 2012-11-26 09:48:43 -0600 (Mon, 26 Nov 2012)
New Revision: 5883
Modified:
   cgm/trunk/README.CGM
Log:
Update the build instruction, to do check build first, then installation.
Modified: cgm/trunk/README.CGM
--- cgm/trunk/README.CGM	2012-11-21 20:57:12 UTC (rev 5882)
+++ cgm/trunk/README.CGM	2012-11-26 15:48:43 UTC (rev 5883)
@@ -55,10 +55,10 @@
 ACIS libraries are located and other options (run "./configure -h" for
 a list of options).
 3. Make the CGM libraries by typing "make".
-4. Install the CGM libraries by typing "make install" (this installs
+4. Test the libraries using "make check".
+5. Install the CGM libraries by typing "make install" (this installs
 the libraries to the location specified by the --prefix option to
 configure, or to /usr/local by default).
-5. Test the installation using "make test".
 Documentation, Testing, Example Applications
More information about the cgma-dev
