[cgma-dev] How to build the CGMA on Windows 7 64bit + VS2010?
    Jane Hu
    janejhu at gmail.com
    Mon Nov  5 10:57:28 CST 2012
Sorry, I forgot the attachment.
On Mon, Nov 5, 2012 at 10:49 AM, Jane Hu <janejhu at gmail.com> wrote:
> Hello  Zhanghong,
> I understand that at some point, you wanted a simple test for boolean
> operation for a box and a sphere.
> I work on Linux machine, and am currently running on cgm-occ code from our
> trunk location. I just built a small tests of size 1 block and a radius=0.7
> sphere and got results for intersection and subtractions stored in
> intersection.brep and box-sphere.brep(for box subtracts sphere) and
> sphere-box.brep( sphere subtracts box).
> I hope you good luck in your build (sorry I can't be much help on your
> cmake build,) and I hope the testcase and result files can help you save
> some time testing.
> Jane
> On Mon, Nov 5, 2012 at 9:07 AM, Zhanghong Tang <tangzhanghong98 at yahoo.com>wrote:
>> Dear Dr. Grindeanu,
>> Thank you very much for your kindly reply. I attached the VS2010 project
>> created by CMake (64bit.zip). Except that I provided the include and
>> library folders of OOC when configure the CMake, I used all default values
>> to generate VS2010 project.
>> The libraries can be built successfully, however, it failed after I
>> created a simple test project "cgmatest', this project and source code are
>> also attached ('cgmatest.zip').
>> Thanks,
>> Zhanghong Tang
>> --- On *Mon, 11/5/12, Iulian Grindeanu <iulian at mcs.anl.gov>* wrote:
>> From: Iulian Grindeanu <iulian at mcs.anl.gov>
>> Subject: Re: [cgma-dev] How to build the CGMA on Windows 7 64bit + VS2010?
>> To: "Zhanghong Tang" <tangzhanghong98 at yahoo.com>
>> Cc: cgma-dev at mcs.anl.gov
>> Date: Monday, November 5, 2012, 10:40 PM
>> Hello,
>> How did you configure? Even if you use cmake, at some point you need to
>> have a configuration step.
>> You can see what we build every night here:
>> http://gnep.mcs.anl.gov:8010/waterfall?category=cgm
>> Those are all built on a Linux compute node, ubuntu 10.04, 64-bit.
>> The configuration closest to yours' is probably cgm-occ or cgm-occ-sta.
>> These are built on merge cubit 12.2 branch, with occ version 6.5.3
>> http://gnep.mcs.anl.gov:8010/builders/cgm-occ
>> or
>> http://gnep.mcs.anl.gov:8010/builders/cgm-occ-sta
>> If you send your config.log file (or equivalent?) , we may have some
>> clues of what is not working.
>> Best Regards,
>> Iulian
>> Dear all,
>> I have successfully built the project 'cubit_OOC' after I used the
>> version 12.2 from here:
>> https://svn.mcs.anl.gov/repos/ITAPS/cgm/branches/Version12.2/
>> However, after I built a simple example "\test\operation.cpp" and run it,
>> the following error displayed:
>> ERROR: Invalid or unsupported engine: 'OCC'
>> Is there anything I missed?
>> Thanks,
>> Zhanghong Tang
>> Date: Sunday, November 4, 2012, 12:51 AM
>> Hello,
>> It would be good if you can make it work.
>> How did you configure ? Using ccmake or autotools in cygwin?
>> You should configure with-occ OR with-cubit, if you have cubit.
>> It seems that you installed occ, so configure ONLY with-occ.
>> I will be out of email until Monday
>> Iulian
>> Dear Dr. Grindeanu,
>> Thank you very much for pointing out my problem. I thought that the CGMA
>> can work without any other package.
>> Now I have installed Open CASCADE Technology 6.5.3 and rebuild the CGMA
>> project (reset the path by CMake and create the VS2010 projects), the
>> following error displayed when build the cubit_OCC project:
>> 1>------ Build started: Project: ZERO_CHECK, Configuration: Debug x64
>> 1>Build started 2012/11/3 23:41:53.
>> 1>InitializeBuildStatus:
>> 1>  Creating "x64\Debug\ZERO_CHECK\ZERO_CHECK.unsuccessfulbuild" because
>> "AlwaysCreate" was specified.
>> 1>FinalizeBuildStatus:
>> 1>  Deleting file "x64\Debug\ZERO_CHECK\ZERO_CHECK.unsuccessfulbuild".
>> 1>  Touching "x64\Debug\ZERO_CHECK\ZERO_CHECK.lastbuildstate".
>> 1>
>> 1>Build succeeded.
>> 1>
>> 1>Time Elapsed 00:00:00.06
>> 2>------ Build started: Project: cubit_OCC, Configuration: Debug x64
>> 2>Build started 2012/11/3 23:41:53.
>> 2>InitializeBuildStatus:
>> 2>  Touching "cubit_OCC.dir\Debug\cubit_OCC.unsuccessfulbuild".
>> 2>CustomBuild:
>> 2>  All outputs are up-to-date.
>> 2>ClCompile:
>> 2>  OCCModifyEngine.cpp
>> 2>E:\cgma-12.2.0b1\util\CubitMessage.hpp(400): warning C4138: '*/' found
>> outside of comment
>> 2>E:\cgma-12.2.0b1\geom\GeometryQueryEngine.hpp(259): warning C4138: '*/'
>> found outside of comment
>> 2>E:\cgma-12.2.0b1\geom\GeometryQueryEngine.hpp(260): warning C4138: '*/'
>> 2>..\..\..\geom\OCC\OCCModifyEngine.cpp(715): error C2440:
>> '<function-style-cast>' : cannot convert from
>> 'Handle_Geom_RectangularTrimmedSurface' to 'BRepBuilderAPI_MakeFace'
>> 2>          No constructor could take the source type, or constructor
>> overload resolution was ambiguous
>> 2>..\..\..\geom\OCC\OCCModifyEngine.cpp(725): error C2440:
>> 2>..\..\..\geom\OCC\OCCModifyEngine.cpp(744): error C2665:
>> 'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace' : none of the 23
>> overloads could convert all the argument types
>> 2>          C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(104):
>> could be 'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Pln
>> &,const Standard_Real,const Standard_Real,const Standard_Real,const
>> Standard_Real)'
>> 2>          C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(106):
>> or       'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const
>> gp_Cylinder &,const Standard_Real,const Standard_Real,const
>> Standard_Real,const Standard_Real)'
>> 2>          C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(108):
>> or       'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Cone
>> Standard_Real)'
>> 2>          C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(110):
>> or       'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Sphere
>> Standard_Real)'
>> 2>          C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(112):
>> or       'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Torus
>> Standard_Real)'
>> 2>          while trying to match the argument list
>> '(Handle_Geom_BezierSurface, double, double, double, double)'
>> 2>..\..\..\geom\OCC\OCCModifyEngine.cpp(2267): warning C4800:
>> 'Standard_Boolean' : forcing value to bool 'true' or 'false' (performance
>> warning)
>> 2>..\..\..\geom\OCC\OCCModifyEngine.cpp(7913): error C2440:
>> 2>
>> 2>Build FAILED.
>> 2>
>> 2>Time Elapsed 00:00:01.52
>> 3>------ Build started: Project: ALL_BUILD, Configuration: Debug x64
>> 3>Build started 2012/11/3 23:41:54.
>> 3>InitializeBuildStatus:
>> 3>  Creating "x64\Debug\ALL_BUILD\ALL_BUILD.unsuccessfulbuild" because
>> 3>CustomBuild:
>> 3>  Build all projects
>> 3>FinalizeBuildStatus:
>> 3>  Deleting file "x64\Debug\ALL_BUILD\ALL_BUILD.unsuccessfulbuild".
>> 3>  Touching "x64\Debug\ALL_BUILD\ALL_BUILD.lastbuildstate".
>> 3>
>> 3>Build succeeded.
>> 3>
>> 3>Time Elapsed 00:00:02.02
>> 4>------ Skipped Build: Project: INSTALL, Configuration: Debug x64 ------
>> 4>Project not selected to build for this solution configuration
>> ========== Build: 2 succeeded, 1 failed, 7 up-to-date, 1 skipped
>> Could you please take a look at it for me?
>> Thanks,
>> Zhanghong Tang
>> Cc: "CGMA Development" <cgma-dev at mcs.anl.gov>
>> Date: Saturday, November 3, 2012, 10:30 PM
>> Dear Dr. Grindeanu,
>> Thank you very much for your kindly reply. With the help of CMake I have
>> successfully build the libraries. There are 7 libs generated:
>> cgma_init.lib
>> cholla.lib
>> cubit_facet.lib
>> cubit_facetboolstub.lib
>> cubit_geom.lib
>> cubit_util.lib
>> cubit_virtual.lib
>> Hello,
>> So I assume you are on the main branch.
>> You can't use CGM without a geometry engine. Did you read my previous
>> e-mail?
>> You will need to configure with OCC or Cubit.
>> Sorry, I can't be of more help.
>> Iulian
>> I tried to build a simple test "brick.cpp", however, there are some
>> errors when run the example:
>> Facet-based geometry modification is a beta capability.
>> ERROR: This capability is currently disabled.
>> To enable this capability, issue the command 'set developer commands on'.
>> ERROR: In GeometryModifyTool::brick
>>        Problem creating a brick.
>> Assertion failed: brick != 0, file ..\test\brick.cpp, line 42
>> I would like to do a simple test:
>> 1) build a box and a sphere with both center at (0,0,0) and size 1;
>> 2) do boolean operations such as intersection between the box and sphere;
>> 3) output the result to an OFF file.
>> Could anyone give me such a simple example?
>> Thanks,
>> Zhanghong Tang
>> Date: Friday, November 2, 2012, 11:21 PM
>> Hello,
>> I don't know if anybody tried building on Windows, maybe Jane or Tim know.
>> You have to configure with a geometric engine. If you don't have Cubit
>> for your platform, you will need to configure with OCC
>> It seems that you use cygwin.  I know that OCC can be build on Windows,
>> on VS 2010.
>> (http://www.opencascade.org/getocc/require/)
>> You then can try configuring on cygwin with occ. And then look at
>> Makefiles generated to see what would be needed for projects in VS. Or is
>> there a cmake-based build? I think that would be easier to port to Windows.
>> Iulian
>> Dear all,
>> I am trying to build the CGMA on Windows 7 64bit + VS2010. I have
>> attached the project. However, there are hundreds of errors such as:
>> 2>CGMAD.lib(DAG.obj) : error LNK2019: unresolved external symbol "public:
>> __cdecl DLIList<class ModelEntity *>::~DLIList<class ModelEntity *>(void)"
>> (??1?$DLIList at PEAVModelEntity@@@@QEAA at XZ) referenced in function
>> "public: enum CubitStatus __cdecl DAG::get_children_at_level(class
>> DLIList<class ModelEntity *> &,int,class DLIList<class ModelEntity *> &)"
>> (?get_children_at_level at DAG@@QEAA?AW4CubitStatus@
>> @AEAV?$DLIList at PEAVModelEntity@@@@H0 at Z)
>> 2>CGMAD.lib(CAActuateSet.obj) : error LNK2001: unresolved external symbol
>> "public: __cdecl DLIList<class ModelEntity *>::~DLIList<class ModelEntity
>> *>(void)" (??1?$DLIList at PEAVModelEntity@@@@QEAA at XZ)
>> 2>CGMAD.lib(PartitionTool.obj) : error LNK2001: unresolved external
>> symbol "public: __cdecl DLIList<class ModelEntity *>::~DLIList<class
>> ModelEntity *>(void)" (??1?$DLIList at PEAVModelEntity@@@@QEAA at XZ)
>> 2>CGMAD.lib(CompositeTool.obj) : error LNK2001: unresolved external
>> 2>CGMAD.lib(TopologyEntity.obj) : error LNK2001: unresolved external
>> Could anyone help me to take a look at it and give me some hints on how
>> to setup the project or modify some code to successfully build the project?
>> Thanks,
>> Zhanghong Tang
> Jane Hu
> Asst. Researcher
> Dept. of Engineering Physics
> UW @ Madison
> "And we know that for those who love God, that is, for those who are
> called according to his purpose, all things are working together for good."
> (Romans 8:28)
Jane Hu
Asst. Researcher
UW @ Madison
"And we know that for those who love God, that is, for those who are called
(Romans 8:28)
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20121105/76c36475/attachment-0001.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20121105/76c36475/attachment-0001.bin>
More information about the cgma-dev
