[cgma-dev] How to build the CGMA on Windows 7 64bit + VS2010?
Zhanghong Tang
tangzhanghong98 at yahoo.com
Mon Nov 5 10:57:21 CST 2012
Dear Dr. Hu,
Could you please send me the test code and result file?
Zhanghong Tang
--- On Tue, 11/6/12, Jane Hu <janejhu at gmail.com> wrote:
Subject: Re: [cgma-dev] How to build the CGMA on Windows 7 64bit + VS2010?
To: "Zhanghong Tang" <tangzhanghong98 at yahoo.com>
Cc: "Iulian Grindeanu" <iulian at mcs.anl.gov>, cgma-dev at mcs.anl.gov
Date: Tuesday, November 6, 2012, 12:49 AM
Hello Zhanghong,
I understand that at some point, you wanted a simple test for boolean operation for a box and a sphere.
I work on Linux machine, and am currently running on cgm-occ code from our trunk location. I just built a small tests of size 1 block and a radius=0.7 sphere and got results for intersection and subtractions stored in intersection.brep and box-sphere.brep(for box subtracts sphere) and sphere-box.brep( sphere subtracts box).
I hope you good luck in your build (sorry I can't be much help on your cmake build,) and I hope the testcase and result files can help you save some time testing.
Jane
On Mon, Nov 5, 2012 at 9:07 AM, Zhanghong Tang <tangzhanghong98 at yahoo.com> wrote:
Dear Dr. Grindeanu,
Thank you very much for your kindly reply. I attached the VS2010 project created by CMake (64bit.zip). Except that I provided the include and library folders of OOC when configure the CMake, I used all default values to generate VS2010 project.
The libraries can be built successfully, however, it failed after I created a simple test project "cgmatest', this project and source code are also attached ('cgmatest.zip').
Zhanghong Tang
Cc: cgma-dev at mcs.anl.gov
Date: Monday, November 5, 2012, 10:40 PM
Hello,
How did you configure? Even if you use cmake, at some point you need to have a configuration step.
You can see what we build every night here:
http://gnep.mcs.anl.gov:8010/waterfall?category=cgm
Those are all built on a Linux compute node, ubuntu 10.04, 64-bit.
The configuration closest to yours' is probably cgm-occ or cgm-occ-sta.
These are built on merge cubit 12.2 branch, with occ version 6.5.3
http://gnep.mcs.anl.gov:8010/builders/cgm-occ
or
http://gnep.mcs.anl.gov:8010/builders/cgm-occ-sta
If you send your config.log file (or equivalent?) , we may have some clues of what is not working.
Best
Iulian
Dear all,
I have successfully built the project 'cubit_OOC' after I used the version 12.2 from here:
https://svn.mcs.anl.gov/repos/ITAPS/cgm/branches/Version12.2/
However, after I built a simple example "\test\operation.cpp" and run it, the following error displayed:
ERROR: Invalid or unsupported engine: 'OCC'
Is there anything I missed?
Zhanghong Tang
VS2010?
Date: Sunday, November 4, 2012, 12:51 AM
Hello,
It would be good if you can make it work.
How did you configure ? Using ccmake or autotools in cygwin?
You should configure with-occ OR with-cubit, if you have cubit.
It seems that you installed occ, so configure ONLY with-occ.
I will be out of email until Monday
Iulian
Dear Dr. Grindeanu,
Thank you very much for pointing out my problem. I thought that the CGMA can work without any other package.
Now I have
installed Open CASCADE Technology 6.5.3 and rebuild the CGMA project (reset the path by CMake and create the VS2010 projects), the
following error displayed when build the cubit_OCC project:
1>------ Build started: Project: ZERO_CHECK, Configuration: Debug x64 ------
1>Build started 2012/11/3 23:41:53.
1>InitializeBuildStatus:
1> Creating "x64\Debug\ZERO_CHECK\ZERO_CHECK.unsuccessfulbuild" because "AlwaysCreate" was specified.
1>FinalizeBuildStatus:
1> Deleting file "x64\Debug\ZERO_CHECK\ZERO_CHECK.unsuccessfulbuild".
1> Touching "x64\Debug\ZERO_CHECK\ZERO_CHECK.lastbuildstate".
1>
1>Build succeeded.
1>
1>Time Elapsed
00:00:00.06
2>------ Build started: Project: cubit_OCC, Configuration: Debug x64 ------
2>Build started 2012/11/3 23:41:53.
2>InitializeBuildStatus:
2> Touching "cubit_OCC.dir\Debug\cubit_OCC.unsuccessfulbuild".
2>CustomBuild:
2> All outputs are up-to-date.
2>ClCompile:
2> OCCModifyEngine.cpp
2>E:\cgma-12.2.0b1\util\CubitMessage.hpp(400): warning C4138: '*/' found outside of comment
2>E:\cgma-12.2.0b1\geom\GeometryQueryEngine.hpp(259): warning C4138: '*/' found outside of comment
2>E:\cgma-12.2.0b1\geom\GeometryQueryEngine.hpp(260): warning C4138: '*/' found outside of comment
2>..\..\..\geom\OCC\OCCModifyEngine.cpp(715): error C2440: '<function-style-cast>' : cannot convert from 'Handle_Geom_RectangularTrimmedSurface' to 'BRepBuilderAPI_MakeFace'
2> No constructor could take the source type, or
constructor overload resolution was ambiguous
2>..\..\..\geom\OCC\OCCModifyEngine.cpp(725): error C2440: '<function-style-cast>' : cannot convert from 'Handle_Geom_RectangularTrimmedSurface' to 'BRepBuilderAPI_MakeFace'
2> No constructor could take the source type, or constructor overload resolution was ambiguous
2>..\..\..\geom\OCC\OCCModifyEngine.cpp(744): error C2665: 'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace' : none of the 23 overloads could convert all the argument types
2> C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(104): could be 'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Pln &,const Standard_Real,const Standard_Real,const Standard_Real,const Standard_Real)'
2>
C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(106): or 'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Cylinder &,const Standard_Real,const Standard_Real,const Standard_Real,const Standard_Real)'
2> C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(108): or 'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Cone &,const Standard_Real,const Standard_Real,const Standard_Real,const Standard_Real)'
2> C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(110): or 'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Sphere &,const Standard_Real,const Standard_Real,const Standard_Real,const Standard_Real)'
2>
C:\OpenCASCADE6.5.3\ros\inc\BRepBuilderAPI_MakeFace.hxx(112): or 'BRepBuilderAPI_MakeFace::BRepBuilderAPI_MakeFace(const gp_Torus &,const Standard_Real,const Standard_Real,const Standard_Real,const Standard_Real)'
2> while trying to match the argument list '(Handle_Geom_BezierSurface, double, double, double, double)'
2>..\..\..\geom\OCC\OCCModifyEngine.cpp(2267): warning C4800: 'Standard_Boolean' : forcing value to bool 'true' or 'false' (performance warning)
2>..\..\..\geom\OCC\OCCModifyEngine.cpp(7913): error C2440: '<function-style-cast>' : cannot convert from 'Handle_Geom_RectangularTrimmedSurface' to 'BRepBuilderAPI_MakeFace'
2>
2>Build FAILED.
2>
2>Time
Elapsed 00:00:01.52
3>------ Build started: Project: ALL_BUILD, Configuration: Debug x64 ------
3>Build started 2012/11/3 23:41:54.
3>InitializeBuildStatus:
3> Creating "x64\Debug\ALL_BUILD\ALL_BUILD.unsuccessfulbuild" because "AlwaysCreate" was specified.
3>CustomBuild:
3> Build all projects
3>FinalizeBuildStatus:
3> Deleting file "x64\Debug\ALL_BUILD\ALL_BUILD.unsuccessfulbuild".
3> Touching "x64\Debug\ALL_BUILD\ALL_BUILD.lastbuildstate".
3>
3>Build succeeded.
3>
3>Time Elapsed 00:00:02.02
4>------ Skipped Build: Project: INSTALL, Configuration: Debug x64 ------
4>Project not selected to build for this solution configuration
========== Build: 2 succeeded, 1 failed, 7 up-to-date, 1 skipped ==========
Could you please take a look at it for me?
Zhanghong Tang
--- On Sat, 11/3/12, Iulian
Cc: "CGMA Development" <cgma-dev at mcs.anl.gov>
Date: Saturday, November 3, 2012, 10:30 PM
Dear Dr. Grindeanu,
Thank you very much for your kindly reply. With the
help of CMake I have successfully build the libraries. There are 7 libs generated:
cgma_init.lib
cholla.lib
cubit_facet.lib
cubit_facetboolstub.lib
cubit_geom.lib
cubit_util.lib
cubit_virtual.lib
Hello,
So I assume you are on the main branch.
You can't use CGM without a geometry engine. Did you read my previous e-mail?
You will need to configure with OCC or Cubit.
Sorry, I can't be of more help.
Iulian
I tried to build a simple test "brick.cpp", however, there are some errors when run the example:
Facet-based geometry modification is a beta capability.
ERROR: This capability is currently disabled.
To enable this capability, issue the command 'set developer
commands on'.
ERROR: In GeometryModifyTool::brick
Problem creating a brick.
Assertion failed: brick != 0, file ..\test\brick.cpp, line 42
I would like to do a simple test:
1) build a box and a sphere with both center at (0,0,0) and size
1;
2) do boolean operations such as intersection between the box and sphere;
3) output the result to an OFF file.
Could anyone give me such a simple example?
Zhanghong Tang
Date: Friday, November 2, 2012, 11:21 PM
Hello,
I don't know if anybody tried building on Windows, maybe Jane or Tim know.
You have to configure
with a geometric engine. If you don't have Cubit for your platform, you will need to configure with OCC
It seems that you use cygwin. I know that OCC can be build on Windows, on VS 2010.
(http://www.opencascade.org/getocc/require/)
You then can try configuring on cygwin with occ. And then look at Makefiles generated to see what would be needed for projects in VS. Or is there a cmake-based build? I think that would be easier to port to Windows.
Iulian
Dear all,
I am trying to build the CGMA on Windows 7 64bit + VS2010. I have attached the project. However, there are hundreds of errors such as:
2>CGMAD.lib(DAG.obj) : error LNK2019: unresolved external symbol "public: __cdecl
DLIList<class ModelEntity *>::~DLIList<class ModelEntity *>(void)" (??1?$DLIList at PEAVModelEntity@@@@QEAA at XZ) referenced in function "public: enum CubitStatus __cdecl DAG::get_children_at_level(class DLIList<class ModelEntity *> &,int,class DLIList<class ModelEntity *> &)" (?get_children_at_level at DAG@@QEAA?AW4CubitStatus@@AEAV?$DLIList at PEAVModelEntity@@@@H0 at Z)
2>CGMAD.lib(CAActuateSet.obj) : error LNK2001: unresolved external symbol "public: __cdecl DLIList<class ModelEntity *>::~DLIList<class ModelEntity *>(void)"
2>CGMAD.lib(PartitionTool.obj) : error LNK2001: unresolved external symbol "public: __cdecl DLIList<class ModelEntity *>::~DLIList<class ModelEntity *>(void)" (??1?$DLIList at PEAVModelEntity@@@@QEAA at XZ)
2>CGMAD.lib(CompositeTool.obj) : error LNK2001: unresolved external symbol "public: __cdecl DLIList<class ModelEntity *>::~DLIList<class ModelEntity *>(void)" (??1?$DLIList at PEAVModelEntity@@@@QEAA at XZ)
2>CGMAD.lib(TopologyEntity.obj) : error LNK2001: unresolved external symbol "public: __cdecl DLIList<class ModelEntity *>::~DLIList<class ModelEntity *>(void)" (??1?$DLIList at PEAVModelEntity@@@@QEAA at XZ)
Could anyone help me to take a look at it and give me some hints on how to setup the project or modify some code to successfully build the project?
Zhanghong
Tang
Jane Hu
Asst. Researcher
Dept. of Engineering Physics
UW @ Madison
"And we know that for those who love God, that is, for those who are
called according to his purpose, all things are working together for
good." (Romans 8:28)
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20121105/b3b5781b/attachment-0001.html>
More information about the cgma-dev
