[cgma-dev] buildbot failure in cgm-occ-par: failed test
    Jane Hu
    janejhu at gmail.com
    Wed Oct 17 09:26:56 CDT 2012
Do a 'make distclean' may clear the problems.
Jane
On Wed, Oct 17, 2012 at 12:30 AM, <cgma-dev at mcs.anl.gov> wrote:
> Fathom <http://gnep.mcs.anl.gov:8010/>: cgm-occ-par<http://gnep.mcs.anl.gov:8010/builders/cgm-occ-par>build
> #38 <http://gnep.mcs.anl.gov:8010/builders/cgm-occ-par/builds/38> *
> Results:*failed test *Buildslave:*gnep *Revision:*None *Reason:*The
> Nightly scheduler named 'cgm-occ-par-nightly' triggered this build Log
> Excerpt
> Making check in OCC
> make[3]: Entering directory `/disks/itaps-buildslave/cgm-occ-par/build/geom/OCC'
> make[3]: Nothing to be done for `check'.
>  ...Making check in init
> make[2]: Entering directory `/disks/itaps-buildslave/cgm-occ-par/build/init'
> make[2]: Nothing to be done for `check'.
>  ...Making check in .
> make[2]: Entering directory `/disks/itaps-buildslave/cgm-occ-par/build'
> make[2]: Nothing to be done for `check-am'.
>  ...Making check in itaps
> make[2]: Entering directory `/disks/itaps-buildslave/cgm-occ-par/build/itaps'
> make  check-recursive
> make[3]: Entering directory `/disks/itaps-buildslave/cgm-occ-par/build/itaps'
> Making check in .
> make[4]: Entering directory `/disks/itaps-buildslave/cgm-occ-par/build/itaps'
> make  chaman test_edge_orient   testgeom_occ copy_attrib partest
> make[5]: Entering directory `/disks/itaps-buildslave/cgm-occ-par/build/itaps'
> /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom   -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -DSRCDIR=. -I../util -I../geom -I../init -I../geom/parallel -DUSE_MPI  -DFORCE_OCC   -Wall -pipe -pedantic -O2 -DNDEBUG -MT partest-partest.o -MD -MP -MF .deps/partest-partest.Tpo -c -o partest-partest.o `test -f 'partest.cpp' || echo './'`partest.cpp
> In file included from ../geom/parallel/CGMmpi.h:11,
>                  from partest.cpp:15:
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpi.h:373: warning: ISO C++ 1998 does not support ‘long long’
> partest.cpp: In function ‘int main(int, char**)’:
> partest.cpp:72: warning: ‘rss_before’ may be used uninitialized in this function
> partest.cpp:72: warning: ‘size_before’ may be used uninitialized in this function
> mv -f .deps/partest-partest.Tpo .deps/partest-partest.Po
> /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -DSRCDIR=. -I../util -I../geom -I../init -I../geom/parallel -DUSE_MPI    -Wall -pipe -pedantic -O2 -DNDEBUG -MT chaman.o -MD -MP -MF .deps/chaman.Tpo -c -o chaman.o chaman.cc
> /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -DSRCDIR=. -I../util -I../geom -I../init -I../geom/parallel -DUSE_MPI    -Wall -pipe -pedantic -O2 -DNDEBUG -MT test_edge_orient.o -MD -MP -MF .deps/test_edge_orient.Tpo -c -o test_edge_orient.o test_edge_orient.cc
> /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom   -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -DSRCDIR=. -I../util -I../geom -I../init -I../geom/parallel -DUSE_MPI  -DFORCE_OCC   -Wall -pipe -pedantic -O2 -DNDEBUG -MT testgeom_occ-testgeom.o -MD -MP -MF .deps/testgeom_occ-testgeom.Tpo -c -o testgeom_occ-testgeom.o `test -f 'testgeom.cc' || echo './'`testgeom.cc
> /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -DSRCDIR=. -I../util -I../geom -I../init -I../geom/parallel -DUSE_MPI    -Wall -pipe -pedantic -O2 -DNDEBUG -MT copy_attrib.o -MD -MP -MF .deps/copy_attrib.Tpo -c -o copy_attrib.o copy_attrib.cpp
> mv -f .deps/chaman.Tpo .deps/chaman.Po
> /bin/sh ../libtool  --tag=CXX   --mode=link /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx  -Wall -pipe -pedantic -O2 -DNDEBUG  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib  -o partest partest-partest.o libiGeom.la -lTKernel -lm
> mv -f .deps/copy_attrib.Tpo .deps/copy_attrib.Po
> /bin/sh ../libtool  --tag=CXX   --mode=link /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx  -Wall -pipe -pedantic -O2 -DNDEBUG  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib  -o chaman chaman.o libiGeom.la -lTKernel -lm
> mv -f .deps/test_edge_orient.Tpo .deps/test_edge_orient.Po
> /bin/sh ../libtool  --tag=CXX   --mode=link /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx  -Wall -pipe -pedantic -O2 -DNDEBUG  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib  -o copy_attrib copy_attrib.o libiGeom.la -lTKernel -lm
> libtool: link: /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -Wall -pipe -pedantic -O2 -DNDEBUG -o .libs/partest partest-partest.o  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib ./.libs/libiGeom.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKernel.so -lm -Wl,-rpath -Wl,/homes/fathom/install/occpar/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib
> libtool: link: /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -Wall -pipe -pedantic -O2 -DNDEBUG -o .libs/chaman chaman.o  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib ./.libs/libiGeom.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKernel.so -lm -Wl,-rpath -Wl,/homes/fathom/install/occpar/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib
> libtool: link: /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -Wall -pipe -pedantic -O2 -DNDEBUG -o .libs/copy_attrib copy_attrib.o  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib ./.libs/libiGeom.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKernel.so -lm -Wl,-rpath -Wl,/homes/fathom/install/occpar/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib
> mv -f .deps/testgeom_occ-testgeom.Tpo .deps/testgeom_occ-testgeom.Po
> /bin/sh ../libtool  --tag=CXX   --mode=link /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx  -Wall -pipe -pedantic -O2 -DNDEBUG  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib  -o test_edge_orient test_edge_orient.o libiGeom.la -lTKernel -lm
> /homes/fathom/install/occpar/cgm/lib/libcgm.so.0: undefined reference to `Standard_PI'
> collect2: ld returned 1 exit status
>  ...make[5]: *** Waiting for unfinished jobs....
>  .../homes/fathom/install/occpar/cgm/lib/libcgm.so.0: undefined reference to `Standard_PI'
>  ...libtool: link: /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -Wall -pipe -pedantic -O2 -DNDEBUG -o .libs/test_edge_orient test_edge_orient.o  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib ./.libs/libiGeom.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKernel.so -lm -Wl,-rpath -Wl,/homes/fathom/install/occpar/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib
Jane Hu
Asst. Researcher
Dept. of Engineering Physics
UW @ Madison
"And we know that for those who love God, that is, for those who are called
according to his purpose, all things are working together for good."
(Romans 8:28)
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20121017/df72ec4c/attachment.html>
More information about the cgma-dev
