[cgma-dev] r5790 - cgm/trunk/geom/virtual
    Jane Hu
    janejhu at gmail.com
    Fri Oct 12 09:39:13 CDT 2012
Thanks, Iulian. It's right.
Jane
On Thu, Oct 11, 2012 at 6:11 PM, <iulian at mcs.anl.gov> wrote:
> Author: iulian
> Date: 2012-10-11 18:11:25 -0500 (Thu, 11 Oct 2012)
> New Revision: 5790
> Removed:
>    cgm/trunk/geom/virtual/libcubit_virtual.la
> Log:
> this file should not be part of repository
> Deleted: cgm/trunk/geom/virtual/libcubit_virtual.la
> --- cgm/trunk/geom/virtual/libcubit_virtual.la  2012-10-11 23:10:10 UTC
> (rev 5789)
> +++ cgm/trunk/geom/virtual/libcubit_virtual.la  2012-10-11 23:11:25 UTC
> (rev 5790)
> @@ -1,41 +0,0 @@
> -# libcubit_virtual.la - a libtool library file
> -# Generated by libtool (GNU libtool) 2.4.2 Debian-2.4.2-1ubuntu1
> -# Please DO NOT delete this file!
> -# It is necessary for linking the library.
> -# The name that we can dlopen(3).
> -dlname='libcubit_virtual.so.0'
> -# Names of this library.
> -library_names='libcubit_virtual.so.0.0.0 libcubit_virtual.so.0
> libcubit_virtual.so'
> -# The name of the static archive.
> -old_library='libcubit_virtual.a'
> -# Linker flags that can not go in dependency_libs.
> -inherited_linker_flags=''
> -# Libraries that this one depends upon.
> -dependency_libs=' /mnt/disk2b/jhu/build653/lib/libTKernel.la -lrt -lXt
> -lX11 -ldl -lpthread'
> -# Names of additional weak libraries provided by this library
> -weak_library_names=''
> -# Version information for libcubit_virtual.
> -current=0
> -age=0
> -revision=0
> -# Is this an already installed library?
> -installed=no
> -# Should we warn about portability when linking against -modules?
> -shouldnotlink=no
> -# Files to dlopen/dlpreopen
> -dlopen=''
> -dlpreopen=''
> -# Directory that this library needs to be installed in:
> -libdir='/mnt/disk2b/jhu/build653/lib'
Jane Hu
Asst. Researcher
Dept. of Engineering Physics
UW @ Madison
"And we know that for those who love God, that is, for those who are called
according to his purpose, all things are working together for good."
(Romans 8:28)
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20121012/49cc91e7/attachment-0001.html>
More information about the cgma-dev
