[cgma-dev] r5790 - cgm/trunk/geom/virtual
    iulian at mcs.anl.gov
    Thu Oct 11 18:11:25 CDT 2012
Author: iulian
Date: 2012-10-11 18:11:25 -0500 (Thu, 11 Oct 2012)
New Revision: 5790
Removed:
   cgm/trunk/geom/virtual/libcubit_virtual.la
Log:
this file should not be part of repository
Deleted: cgm/trunk/geom/virtual/libcubit_virtual.la
--- cgm/trunk/geom/virtual/libcubit_virtual.la	2012-10-11 23:10:10 UTC (rev 5789)
+++ cgm/trunk/geom/virtual/libcubit_virtual.la	2012-10-11 23:11:25 UTC (rev 5790)
@@ -1,41 +0,0 @@
-# libcubit_virtual.la - a libtool library file
-# Generated by libtool (GNU libtool) 2.4.2 Debian-2.4.2-1ubuntu1
-# Please DO NOT delete this file!
-# It is necessary for linking the library.
-# The name that we can dlopen(3).
-dlname='libcubit_virtual.so.0'
-# Names of this library.
-library_names='libcubit_virtual.so.0.0.0 libcubit_virtual.so.0 libcubit_virtual.so'
-# The name of the static archive.
-old_library='libcubit_virtual.a'
-# Linker flags that can not go in dependency_libs.
-inherited_linker_flags=''
-# Libraries that this one depends upon.
-dependency_libs=' /mnt/disk2b/jhu/build653/lib/libTKernel.la -lrt -lXt -lX11 -ldl -lpthread'
-# Names of additional weak libraries provided by this library
-weak_library_names=''
-# Version information for libcubit_virtual.
-current=0
-age=0
-revision=0
-# Is this an already installed library?
-installed=no
-# Should we warn about portability when linking against -modules?
-shouldnotlink=no
-# Files to dlopen/dlpreopen
-dlopen=''
-dlpreopen=''
-# Directory that this library needs to be installed in:
-libdir='/mnt/disk2b/jhu/build653/lib'
More information about the cgma-dev
