[cgma-dev] r5778 - in cgm/branches/merge-cubit12.2/util/OtherFiles:	. CGMWindowsLib
    janehu at mcs.anl.gov
    Tue Oct  9 13:38:45 CDT 2012
Author: janehu
Date: 2012-10-09 13:38:45 -0500 (Tue, 09 Oct 2012)
New Revision: 5778
Added:
   cgm/branches/merge-cubit12.2/util/OtherFiles/CGMWindowsLib/
   cgm/branches/merge-cubit12.2/util/OtherFiles/CGMWindowsLib/CGMWindowsLib.dsp
   cgm/branches/merge-cubit12.2/util/OtherFiles/CUBIT.hp
   cgm/branches/merge-cubit12.2/util/OtherFiles/CUBIT.lin
   cgm/branches/merge-cubit12.2/util/OtherFiles/CUBIT.sg
   cgm/branches/merge-cubit12.2/util/OtherFiles/cubit_cshrc.csh
   cgm/branches/merge-cubit12.2/util/OtherFiles/dot_cubit_reset
   cgm/branches/merge-cubit12.2/util/OtherFiles/idr.vbs
   cgm/branches/merge-cubit12.2/util/OtherFiles/sierra.dbg.ibm
   cgm/branches/merge-cubit12.2/util/OtherFiles/sierra.dbg.janus
   cgm/branches/merge-cubit12.2/util/OtherFiles/sierra.dbg.lin
   cgm/branches/merge-cubit12.2/util/OtherFiles/sierra.dbg.sg
   cgm/branches/merge-cubit12.2/util/OtherFiles/sierra.opt.sg
   cgm/branches/merge-cubit12.2/util/OtherFiles/sierra.opt.ss
Log:
Added: cgm/branches/merge-cubit12.2/util/OtherFiles/CGMWindowsLib/CGMWindowsLib.dsp
--- cgm/branches/merge-cubit12.2/util/OtherFiles/CGMWindowsLib/CGMWindowsLib.dsp	                        (rev 0)
+++ cgm/branches/merge-cubit12.2/util/OtherFiles/CGMWindowsLib/CGMWindowsLib.dsp	2012-10-09 18:38:45 UTC (rev 5778)
@@ -0,0 +1,3527 @@
+# Microsoft Developer Studio Project File - Name="CGMWindowsLib" - Package Owner=<4>
+# Microsoft Developer Studio Generated Build File, Format Version 6.00
+# ** DO NOT EDIT **
+# TARGTYPE "Win32 (x86) Static Library" 0x0104
+CFG=CGMWindowsLib - Win32 Debug
+!MESSAGE This is not a valid makefile. To build this project using NMAKE,
+!MESSAGE use the Export Makefile command and run
+!MESSAGE
+!MESSAGE NMAKE /f "CGMWindowsLib.mak".
+!MESSAGE
+!MESSAGE You can specify a configuration when running NMAKE
+!MESSAGE by defining the macro CFG on the command line. For example:
+!MESSAGE
+!MESSAGE NMAKE /f "CGMWindowsLib.mak" CFG="CGMWindowsLib - Win32 Debug"
+!MESSAGE
+!MESSAGE Possible choices for configuration are:
+!MESSAGE
+!MESSAGE "CGMWindowsLib - Win32 Release" (based on "Win32 (x86) Static Library")
+!MESSAGE "CGMWindowsLib - Win32 Debug" (based on "Win32 (x86) Static Library")
+!MESSAGE
+# Begin Project
+# PROP AllowPerConfigDependencies 0
+# PROP Scc_ProjName ""
+# PROP Scc_LocalPath ""
+CPP=cl.exe
+F90=df.exe
+RSC=rc.exe
+!IF  "$(CFG)" == "CGMWindowsLib - Win32 Release"
+# PROP BASE Use_MFC 0
+# PROP BASE Use_Debug_Libraries 0
+# PROP BASE Output_Dir "Release"
+# PROP BASE Intermediate_Dir "Release"
+# PROP BASE Target_Dir ""
+# PROP Use_MFC 0
+# PROP Use_Debug_Libraries 0
+# PROP Output_Dir "Release"
+# PROP Intermediate_Dir "Release"
+# PROP Target_Dir ""
+# ADD BASE F90 /compile_only /nologo /warn:nofileopt
+# ADD F90 /compile_only /nologo /warn:nofileopt
+# ADD BASE CPP /nologo /W3 /GX /O2 /D "WIN32" /D "NDEBUG" /D "_MBCS" /D "_LIB" /YX /FD /c
More information about the cgma-dev
