[cgma-dev] r5777 - in cgm/branches/merge-cubit12.2/geom/ACIS_SRC: .	gtcAttrib gtcAttrib/incl gtcAttrib/src
    janehu at mcs.anl.gov
    Tue Oct  9 13:29:46 CDT 2012
Author: janehu
Date: 2012-10-09 13:29:45 -0500 (Tue, 09 Oct 2012)
New Revision: 5777
Added:
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisBridge.cpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisBridge.hpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisDrawTool.cpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisDrawTool.hpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisEdgeTool.cpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisEdgeTool.hpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisFacetManager.cpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisFeatureEngine.cpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisFeatureEngine.hpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisHealerTool.cpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisHistory.hpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisModifyEngine.cpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisModifyEngine.hpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisQueryEngine.hpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisSurfaceTool.cpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisSurfaceTool.hpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisToolUtil.cpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisToolUtil.hpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisTweakTool.cpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisTypes.h
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/BodyACIS.cpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/CMakeLists.txt
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/CoEdgeACIS.cpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/CoEdgeACIS.hpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/CurveACIS.cpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/CurveACIS.hpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/InstallACIS.cmake.in
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/LumpACIS.cpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/LumpACIS.hpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/Makefile.am
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/PointACIS.cpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/ShellACIS.cpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/ShellACIS.hpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/SurfaceACIS.cpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/SurfaceACIS.hpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/attrib_cubit_owner.cpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/attrib_cubit_owner.hpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/attrib_history.cpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/attrib_history.hpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/attrib_snl.cpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/attrib_snl.hpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/attrib_snl_simple.hpp
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/decl_none.h
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/gtcAttrib/
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/gtcAttrib/CMakeLists.txt
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/gtcAttrib/Makefile
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/gtcAttrib/Makefile.Linux
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/gtcAttrib/Makefile.SunOS
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/gtcAttrib/incl/
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/gtcAttrib/incl/attrib_edge_parametric_length.h
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/gtcAttrib/incl/attrib_gtc.h
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/gtcAttrib/incl/attrib_gtc_export.h
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/gtcAttrib/incl/attrib_mark.h
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/gtcAttrib/incl/attrib_name.h
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/gtcAttrib/incl/gtcAttrib_exConst.h
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/gtcAttrib/src/
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/gtcAttrib/src/attrib_edge_parametric_length.C
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/gtcAttrib/src/attrib_gtc.C
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/gtcAttrib/src/attrib_mark.C
   cgm/branches/merge-cubit12.2/geom/ACIS_SRC/gtcAttrib/src/attrib_name.C
Log:
Add missing files.
Added: cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisBridge.cpp
--- cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisBridge.cpp	                        (rev 0)
+++ cgm/branches/merge-cubit12.2/geom/ACIS_SRC/AcisBridge.cpp	2012-10-09 18:29:45 UTC (rev 5777)
@@ -0,0 +1,317 @@
+// Filename      : AcisBridge.cpp
+// Purpose       : Many functions are identical for each Acis-specific
+//                 TopologyBridge.  This class implements those functions.
+// Creator       : Darryl Melander
+// Creation Date : 03/22/99
+// Owner         : Darryl Melander
+// ************* BEGIN ACIS INCLUDES *************
+#include "api.hxx"
+// ************* END ACIS INCLUDES ***************
+// ************* BEGIN CUBIT INCLUDES *************
+#include "AcisBridge.hpp"
+#include "TopologyBridge.hpp"
+#include "GeometryQueryTool.hpp"
+#include "AcisQueryEngine.hpp"
+#include "CubitSimpleAttrib.hpp"
+#include "attrib_cubit_owner.hpp"
+#include "attrib_snl_simple.hpp"
+#include "attrib_name.h"
+#include "attrib_edge_parametric_length.h"
+#include "CastTo.hpp"
+// ************* END CUBIT INCLUDES ***************
+unsigned AcisBridge::bridgeCount = 0;
+AcisBridge::AcisBridge(ENTITY* entity)
+    : myENTITY(NULL)
+  ENTITY_ptr(entity);
+  bridgeCount++;
+AcisBridge::~AcisBridge()
+  ENTITY_ptr(NULL);
+  bridgeCount--;
More information about the cgma-dev
