[cgma-dev] r5768 - cgm/trunk/test
    Jane Hu
    janejhu at gmail.com
    Mon Oct  8 10:12:14 CDT 2012
Yes, I didn't see the committing email either, thanks for point out the
location.
Jane
On Mon, Oct 8, 2012 at 10:03 AM, Iulian Grindeanu <iulian at mcs.anl.gov>wrote:
> Hi Jane,
> I had to change configure.ac too, and some other Makefile.am. I did not
> get a message for committing, but you can check online what I did.
> http://trac.mcs.anl.gov/projects/ITAPS/changeset/5769
> http://trac.mcs.anl.gov/projects/ITAPS/changeset/5770
> Thanks,
> Iulian
> Thanks, Iulian. I see that you updated test/Makefile.am to add
> $(CGM_EXT_LIBS). Seems it solved the problems!
> Have a nice day!
> Jane
> On Mon, Oct 8, 2012 at 7:16 AM, Iulian Grindeanu <iulian at mcs.anl.gov>wrote:
>> I forgot to commit a file, TestConfig.h.in in the new place, so it
>> didn't work :(
>> It should work tonight
>> Iulian
>> Hi Jane,
>> I think I fixed it, you should double-check on Monday. I restarted the
>> buildbot, so we will know if I fixed it or not :)
>> Best Regards,
>> Iulian
>> I don't get it, I am planning to remove the whole geom/testing, and move
>> its contents to cgm/test. I am not using cmake either, but thought I should
>> keep the *txt file for later reference. Maybe I should change Makefile.am
>> in the parent directory to not look to build test in geom/testing. I'll
>> look into it Monday.
>> Jane
>> On Sat, Oct 6, 2012 at 7:59 AM, Iulian Grindeanu <iulian at mcs.anl.gov>wrote:
>>> Hi Jane,
>>> The buildbot failed last night, because of these and above changes.
>>> (autoreconf -fi failed, I tried on a new working folder)
>>> Buildbot uses autotools, not cmake. So it needs Makefile.am and
>>> TestConfig.h.in, in geom/testing, to generate Makefile and
>>> TestConfig.h.
>>> I will disable the buildbot for the weekend, unless you can fix it.
>>> Thanks,
>>> Iulian
>>> *From: *janehu at mcs.anl.gov
>>> *To: *cgma-dev at mcs.anl.gov
>>> *Sent: *Friday, October 5, 2012 10:58:11 AM
>>> *Subject: *[cgma-dev] r5768 - cgm/trunk/test
>>> Author: janehu
>>> Date: 2012-10-05 10:58:11 -0500 (Fri, 05 Oct 2012)
>>> New Revision: 5768
>>> Added:
>>>    cgm/trunk/test/AngleCalc.cpp
>>>    cgm/trunk/test/CreateGeometry.cpp
>>>    cgm/trunk/test/GraphicsData.cpp
>>>    cgm/trunk/test/TestUtilities.cpp
>>>    cgm/trunk/test/TestUtilities.hpp
>>> Modified:
>>>    cgm/trunk/test/Makefile.am
>>> Log:
>>> Moves geom/testing checks to here,they are basically similiar check-ups
>>> for geometry. Corresponding CMakeLists.txt file is not moved here. Self
>>> study to see if I there's a way to auto-generate CMakeLists.txt from
>>> Makefile.am, passed make check in this directory.
>>> Added: cgm/trunk/test/AngleCalc.cpp
>>> --- cgm/trunk/test/AngleCalc.cpp                                (rev 0)
>>> +++ cgm/trunk/test/AngleCalc.cpp        2012-10-05 15:58:11 UTC (rev
>>> 5768)
>>> @@ -0,0 +1,121 @@
>>> + * \file AngleCalc.cpp
>>> + * \brief AngleCalc, another simple C++ driver for CGM
>>> + * This program acts as a simple driver for CGM.  It reads in a
>>> geometry,
>>> + * and performs varies checks for bodies, surfaces, curves and vertices.
>>> +#undef NDEBUG
>>> +#include <cassert>
>>> +#include "stdio.h"
>>> +#include "GeometryQueryTool.hpp"
>>> +#include "GeometryModifyTool.hpp"
>>> +#include "RefEdge.hpp"
>>> +#include "RefVertex.hpp"
>>> +#include "CoEdge.hpp"
>>> +#include "RefFace.hpp"
>>> +#include "CubitDefines.h"
>>> +#include "CubitBox.hpp"
>>> +#include "InitCGMA.hpp"
>>> +#include "TestUtilities.hpp"
>>> +#ifndef SRCDIR
>>> +# define SRCDIR .
>>> +#endif
>>> +#ifdef TEST_ACIS
>>> +#  define ENGINE "ACIS"
>>> +#elif defined (TEST_OCC)
>>> +#  define ENGINE "OCC"
>>> +#else
>>> +#  error "Which engine to test?"
>>> +#endif
>>> +#define STRINGIFY_(X) #X
>>> +#define STRINGIFY(X) STRINGIFY_(X)
>>> +#define SRCPATH STRINGIFY(SRCDIR) "/"
>>> +// forward declare some functions used and defined later
>>> +int AngleCalc();
>>> +// macro for printing a separator line
>>> +#define PRINT_SEPARATOR
>>> PRINT_INFO("=======================================\n");
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20121008/925835c6/attachment.html>
More information about the cgma-dev
