[cgma-dev] r5768 - cgm/trunk/test
Iulian Grindeanu
iulian at mcs.anl.gov
Mon Oct 8 10:03:11 CDT 2012
Hi Jane,
I had to change configure.ac too, and some other Makefile.am. I did not get a message for committing, but you can check online what I did.
http://trac.mcs.anl.gov/projects/ITAPS/changeset/5769
http://trac.mcs.anl.gov/projects/ITAPS/changeset/5770
Iulian
----- Original Message -----
| Thanks, Iulian. I see that you updated test/Makefile.am to add
| $(CGM_EXT_LIBS). Seems it solved the problems!
| Have a nice day!
| Jane
| On Mon, Oct 8, 2012 at 7:16 AM, Iulian Grindeanu < iulian at mcs.anl.gov
| > wrote:
| | I forgot to commit a file, TestConfig.h.in in the new place, so it
| | didn't work :(
| | It should work tonight
| | Iulian
| | | Hi Jane,
| | | I think I fixed it, you should double-check on Monday. I restarted
| | | the
| | | buildbot, so we will know if I fixed it or not :)
| | | Best Regards,
| | | Iulian
| | | | I don't get it, I am planning to remove the whole geom/testing,
| | | | and
| | | | move its contents to cgm/test. I am not using cmake either, but
| | | | thought I should keep the *txt file for later reference. Maybe I
| | | | should change Makefile.am in the parent directory to not look to
| | | | build
| | | | test in geom/testing. I'll look into it Monday.
| | | | Jane
| | | | On Sat, Oct 6, 2012 at 7:59 AM, Iulian Grindeanu <
| | | | > wrote:
| | | | | Hi Jane,
| | | | | The buildbot failed last night, because of these and above
| | | | | changes.
| | | | | (autoreconf -fi failed, I tried on a new working folder)
| | | | | Buildbot uses autotools, not cmake. So it needs Makefile.am
| | | | | and
| | | | | TestConfig.h.in , in geom/testing, to generate Makefile and
| | | | | TestConfig.h.
| | | | | I will disable the buildbot for the weekend, unless you can
| | | | | fix
| | | | | it.
| | | | | Thanks,
| | | | | Iulian
| | | | | To: cgma-dev at mcs.anl.gov
| | | | | Sent: Friday, October 5, 2012 10:58:11 AM
| | | | | Subject: [cgma-dev] r5768 - cgm/trunk/test
| | | | | Author: janehu
| | | | | Date: 2012-10-05 10:58:11 -0500 (Fri, 05 Oct 2012)
| | | | | New Revision: 5768
| | | | | Added:
| | | | | cgm/trunk/test/AngleCalc.cpp
| | | | | cgm/trunk/test/CreateGeometry.cpp
| | | | | cgm/trunk/test/GraphicsData.cpp
| | | | | cgm/trunk/test/TestUtilities.cpp
| | | | | cgm/trunk/test/TestUtilities.hpp
| | | | | Modified:
| | | | | cgm/trunk/test/Makefile.am
| | | | | Log:
| | | | | Moves geom/testing checks to here,they are basically similiar
| | | | | check-ups for geometry. Corresponding CMakeLists.txt file is
| | | | | not
| | | | | moved
| | | | | here. Self study to see if I there's a way to auto-generate
| | | | | CMakeLists.txt from Makefile.am, passed make check in this
| | | | | directory.
| | | | | Added: cgm/trunk/test/AngleCalc.cpp
| | | | | --- cgm/trunk/test/AngleCalc.cpp (rev 0)
| | | | | +++ cgm/trunk/test/AngleCalc.cpp 2012-10-05 15:58:11 UTC (rev
| | | | | 5768)
| | | | | @@ -0,0 +1,121 @@
| | | | | + * \file AngleCalc.cpp
| | | | | + * \brief AngleCalc, another simple C++ driver for CGM
| | | | | + * This program acts as a simple driver for CGM. It reads in
| | | | | a
| | | | | geometry,
| | | | | + * and performs varies checks for bodies, surfaces, curves
| | | | | and
| | | | | vertices.
| | | | | +#undef NDEBUG
| | | | | +#include <cassert>
| | | | | +#include "stdio.h"
| | | | | +#include "GeometryQueryTool.hpp"
| | | | | +#include "GeometryModifyTool.hpp"
| | | | | +#include "RefEdge.hpp"
| | | | | +#include "RefVertex.hpp"
| | | | | +#include "CoEdge.hpp"
| | | | | +#include "RefFace.hpp"
| | | | | +#include "CubitDefines.h"
| | | | | +#include "CubitBox.hpp"
| | | | | +#include "InitCGMA.hpp"
| | | | | +#include "TestUtilities.hpp"
| | | | | +#ifndef SRCDIR
| | | | | +# define SRCDIR .
| | | | | +#endif
| | | | | +#ifdef TEST_ACIS
| | | | | +# define ENGINE "ACIS"
| | | | | +#elif defined (TEST_OCC)
| | | | | +# define ENGINE "OCC"
| | | | | +#else
| | | | | +# error "Which engine to test?"
| | | | | +#endif
| | | | | +#define STRINGIFY_(X) #X
| | | | | +#define STRINGIFY(X) STRINGIFY_(X)
| | | | | +#define SRCPATH STRINGIFY(SRCDIR) "/"
| | | | | +// forward declare some functions used and defined later
| | | | | +int AngleCalc();
| | | | | +// macro for printing a separator line
| | | | | +#define PRINT_SEPARATOR
| | | | | PRINT_INFO("=======================================\n");
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20121008/8be9bf09/attachment.html>
More information about the cgma-dev
