[cgma-dev] Make check errors...
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Thu Sep 27 18:31:42 CDT 2012
OK, done
Best regards,
Iulian
----- Original Message -----
| It could, but would make inserting new tests just a bit harder. The
| right way to do it is to tweak the dependencies to
| account for all the other external libs; Iulian has a fix which does
| that which he'll commit shortly.
| - tim
| On 09/27/2012 05:29 PM, Paul Wilson wrote:
| > On 09/27/2012 04:31 PM, Tim Tautges wrote:
| >> Anyway, Paul, cgm.make is for applications built outside the cgm
| >> autotools setup, while make check is for things
| >> inside that setup.
| > But if the cgm.make methodology works for built apps, couldn't a
| > similar paradigm - maybe just a different file - be
| > invoked for the make check.
| > Paul
| "You will keep in perfect peace him whose mind is
| steadfast, because he trusts in you." Isaiah 26:3
| Tim Tautges Argonne National Laboratory
| (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
| phone (gvoice): (608) 354-1459 1500 Engineering Dr.
| fax: (608) 263-4499 Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120927/541eec6c/attachment.html>
More information about the cgma-dev
