[cgma-dev] Make check errors...
    Tim Tautges
    tautges at mcs.anl.gov
    Thu Sep 27 18:20:04 CDT 2012
It could, but would make inserting new tests just a bit harder.  The right way to do it is to tweak the dependencies to
account for all the other external libs; Iulian has a fix which does that which he'll commit shortly.
- tim
On 09/27/2012 05:29 PM, Paul Wilson wrote:
> On 09/27/2012 04:31 PM, Tim Tautges wrote:
>> Anyway, Paul, cgm.make is for applications built outside the cgm autotools setup, while make check is for things
>> inside that setup.
> But if the cgm.make methodology works for built apps, couldn't a similar paradigm - maybe just a different file - be
> invoked for the make check.
> Paul
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev
