[cgma-dev] r5542 - cgm/branches/merge-cubit13.1/test
    jiangtao_ma at yahoo.com
    Mon Jun  4 10:06:55 CDT 2012
Author: janehu
Date: 2012-06-04 10:06:54 -0500 (Mon, 04 Jun 2012)
New Revision: 5542
Removed:
   cgm/branches/merge-cubit13.1/test/OffsetCurves.brep
   cgm/branches/merge-cubit13.1/test/aftersub.occ_ref
   cgm/branches/merge-cubit13.1/test/beforesub.occ_ref
   cgm/branches/merge-cubit13.1/test/beforesub2.occ_ref
Modified:
   cgm/branches/merge-cubit13.1/test/Makefile.am
   cgm/branches/merge-cubit13.1/test/makept.cpp
   cgm/branches/merge-cubit13.1/test/modify.cpp
   cgm/branches/merge-cubit13.1/test/r_w.cpp
   cgm/branches/merge-cubit13.1/test/subtract.cpp
Log:
Updated the testcases to reflect the attribute write out and some file cleanups.
Modified: cgm/branches/merge-cubit13.1/test/Makefile.am
--- cgm/branches/merge-cubit13.1/test/Makefile.am	2012-06-04 14:35:54 UTC (rev 5541)
+++ cgm/branches/merge-cubit13.1/test/Makefile.am	2012-06-04 15:06:54 UTC (rev 5542)
@@ -63,9 +63,6 @@
              66_shaver3.brep \
              72_shaver6.brep \
              LeverArm.brep \
-             aftersub.occ_ref \
-             beforesub.occ_ref \
-             beforesub2.occ_ref \
              unite1.occ\
              huge.sat \
              model1.sat \
@@ -80,7 +77,14 @@
              proe.stp   \
              diffuser.iges   \
              ex3.iges   \
-             stitch.name_occ
+             Cylinder_1.brep   \
+             Cylinder_2.brep   \
+             webcut.brep     \
+             Line_1.brep    \
+             Line_2.brep    \
+             stitch.name_occ \
+             Solid_6.brep  \
+             Solid_7.brep
 # Files that are created by tests, and that therefore
 #  - should be removed during 'make clean'
Deleted: cgm/branches/merge-cubit13.1/test/OffsetCurves.brep
--- cgm/branches/merge-cubit13.1/test/OffsetCurves.brep	2012-06-04 14:35:54 UTC (rev 5541)
+++ cgm/branches/merge-cubit13.1/test/OffsetCurves.brep	2012-06-04 15:06:54 UTC (rev 5542)
@@ -1,212 +0,0 @@
-DBRep_DrawableShape
-CASCADE Topology V1, (c) Matra-Datavision
-Locations 0
-Curve2ds 2
-2 -0 -10 -0 -1 -1 0 11
-2 -0 -10 0 1 1 -0 11
-Curves 8
-7 0 0  3 8 6  10 10 10  7.8962907194978245 9.9328755447232275 10  4.1504640997504039 8.1351109972144258 10.000000000000002  1.714602544470867 3.468838576501712 10.000000000000002  -0.24807223430422448 -0.53560957713195312 10  -2.9384040624443264 -5.4124904340469637 10.000000000000002  -6.2827475623092432 -8.8001177873989569 10  -10 -10 10
- 0 4 5.3851648071345037 1 12.596267358062482 1 14.832335335562272 1 18.863464209711545 1 29.171228273755695 4
-7 0 0  3 8 6  10 10 10  8.8666713916745454 8.8666713916745454 10  3.4843922940546812 8.8157357833931851 10.000000000000002  1.8844626692971531 3.4528242743597368 10.000000000000002  -0.4211062146432315 -0.57327939072379408 10  -0.88697691552815716 -4.7540936064134218 10.000000000000002  -17.604693546281354 -12.534897848760451 10  -10 -10 10
-1 10 10 10 -0.70710678118654746 -0.70710678118654746 0
-9 1
-0 -0 -1
More information about the cgma-dev
