[cgma-dev] r5530 - cgm/trunk
    jvporter at wisc.edu
    Wed May 23 13:47:53 CDT 2012
Author: jvporter
Date: 2012-05-23 13:47:53 -0500 (Wed, 23 May 2012)
New Revision: 5530
Modified:
   cgm/trunk/configure.ac
Log:
Change --enable-shim to --with-shim to allow specifying shim directory
Modified: cgm/trunk/configure.ac
--- cgm/trunk/configure.ac	2012-05-23 17:05:41 UTC (rev 5529)
+++ cgm/trunk/configure.ac	2012-05-23 18:47:53 UTC (rev 5530)
@@ -396,11 +396,22 @@
 #                           ITAPS shim
-AC_ARG_ENABLE([shim],[AC_HELP_STRING([--enable-shim],
-  [Enable ITAPS shim])],
-  [ITAPS_SHIM=$enableval],[ITAPS_SHIM=no])
-AM_CONDITIONAL([ITAPS_SHIM],[test "xyes" = "x$ITAPS_SHIM"])
+AC_ARG_WITH(shim,
+            [AC_HELP_STRING([--with-shim],
+                            [Enable ITAPS shim])],
+            [SHIM_DIR="$withval"],
+            [SHIM_DIR=no])
+AM_CONDITIONAL([ITAPS_SHIM],[test "xno" != "x$SHIM_DIR"])
+if test "x$CUBIT_DIR" == "xyes"; then
+  AC_MSG_ERROR([Option --with-shim without specifying Cubit directory.])
+elif test "x$SHIM_DIR" != "xno"; then
+  if ! test -d "$SHIM_DIR"; then
+    AC_MSG_ERROR([$SHIM_DIR: not a directory.])
+  fi
+  AM_CPPFLAGS="$AM_CPPFLAGS -I$SHIM_DIR"
+fi
 #                           OCC Options
More information about the cgma-dev
