[cgma-dev] r5471 - cgm/branches/merge-cubit13.1
    jiangtao_ma at yahoo.com
    Mon Apr  9 14:53:36 CDT 2012
Author: janehu
Date: 2012-04-09 14:53:35 -0500 (Mon, 09 Apr 2012)
New Revision: 5471
Removed:
   cgm/branches/merge-cubit13.1/aclocal.m4
   cgm/branches/merge-cubit13.1/acsite.m4
   cgm/branches/merge-cubit13.1/autom4te.cache/
   cgm/branches/merge-cubit13.1/cgma-10.2.3/
   cgm/branches/merge-cubit13.1/config.guess
   cgm/branches/merge-cubit13.1/config.h.in
   cgm/branches/merge-cubit13.1/config.sub
   cgm/branches/merge-cubit13.1/config_aux/
   cgm/branches/merge-cubit13.1/configure
   cgm/branches/merge-cubit13.1/depcomp
   cgm/branches/merge-cubit13.1/install-sh
   cgm/branches/merge-cubit13.1/ltmain.sh
   cgm/branches/merge-cubit13.1/missing
   cgm/branches/merge-cubit13.1/temp
Log:
Deleted unnecessary files.
Deleted: cgm/branches/merge-cubit13.1/aclocal.m4
--- cgm/branches/merge-cubit13.1/aclocal.m4	2012-04-09 19:47:32 UTC (rev 5470)
+++ cgm/branches/merge-cubit13.1/aclocal.m4	2012-04-09 19:53:35 UTC (rev 5471)
@@ -1,988 +0,0 @@
-# generated automatically by aclocal 1.11.1 -*- Autoconf -*-
-# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004,
-# 2005, 2006, 2007, 2008, 2009  Free Software Foundation, Inc.
-# This file is free software; the Free Software Foundation
-# gives unlimited permission to copy and/or distribute it,
-# with or without modifications, as long as this notice is preserved.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY, to the extent permitted by law; without
-# even the implied warranty of MERCHANTABILITY or FITNESS FOR A
-# PARTICULAR PURPOSE.
-m4_ifndef([AC_AUTOCONF_VERSION],
-  [m4_copy([m4_PACKAGE_VERSION], [AC_AUTOCONF_VERSION])])dnl
-m4_if(m4_defn([AC_AUTOCONF_VERSION]), [2.65],,
-[m4_warning([this file was generated for autoconf 2.65.
-You have another version of autoconf.  It may work, but is not guaranteed to.
-If you have problems, you may need to regenerate the build system entirely.
-To do so, use the procedure documented by the package, typically `autoreconf'.])])
-# Copyright (C) 2002, 2003, 2005, 2006, 2007, 2008  Free Software Foundation, Inc.
-# AM_AUTOMAKE_VERSION(VERSION)
-# Automake X.Y traces this macro to ensure aclocal.m4 has been
-# generated from the m4 files accompanying Automake X.Y.
-# (This private macro should not be called outside this file.)
-AC_DEFUN([AM_AUTOMAKE_VERSION],
-[am__api_version='1.11'
-dnl Some users find AM_AUTOMAKE_VERSION and mistake it for a way to
-dnl require some minimum version.  Point them to the right macro.
-m4_if([$1], [1.11.1], [],
-      [AC_FATAL([Do not call $0, use AM_INIT_AUTOMAKE([$1]).])])dnl
-# _AM_AUTOCONF_VERSION(VERSION)
-# aclocal traces this macro to find the Autoconf version.
-# This is a private macro too.  Using m4_define simplifies
-# the logic in aclocal, which can simply ignore this definition.
-m4_define([_AM_AUTOCONF_VERSION], [])
More information about the cgma-dev
