[cgma-dev] r5470 - in cgm/branches/merge-cubit13.1/geom: . testing
    jiangtao_ma at yahoo.com
    Mon Apr  9 14:47:33 CDT 2012
Author: janehu
Date: 2012-04-09 14:47:32 -0500 (Mon, 09 Apr 2012)
New Revision: 5470
Removed:
   cgm/branches/merge-cubit13.1/geom/temp
Modified:
   cgm/branches/merge-cubit13.1/geom/testing/Makefile.am
Log:
Removed unnecessary file.
Deleted: cgm/branches/merge-cubit13.1/geom/temp
--- cgm/branches/merge-cubit13.1/geom/temp	2012-04-09 19:43:09 UTC (rev 5469)
+++ cgm/branches/merge-cubit13.1/geom/temp	2012-04-09 19:47:32 UTC (rev 5470)
@@ -1,12928 +0,0 @@
-Index: virtual/VirtualQueryEngine.hpp
---- virtual/VirtualQueryEngine.hpp	(revision 5396)
-+++ virtual/VirtualQueryEngine.hpp	(working copy)
-@@ -450,7 +450,7 @@
-   if( instance_ == NULL )
-     instance_ = new VirtualQueryEngine;
--    assert( instance != NULL );
-+    assert( instance_ != NULL );
-   return instance_;
-Index: virtual/Makefile.am
---- virtual/Makefile.am	(revision 5396)
-+++ virtual/Makefile.am	(working copy)
-@@ -3,7 +3,7 @@
- # Override default defines with the ones we want from the configure script
- DEFS = $(TEMPLATE_DEFS_INCLUDED) $(LITTLE_ENDIAN)
--INCLUDES = -I$(top_srcdir)/util \
-+AM_CPPFLAGS = -I$(top_srcdir)/util \
-            -I$(top_srcdir)/geom \
-            -I$(top_srcdir)/geom/facet \
-            -I$(top_srcdir)/geom/Cholla
-Index: GeometryModifyTool.hpp
---- GeometryModifyTool.hpp	(revision 5396)
-+++ GeometryModifyTool.hpp	(working copy)
-@@ -273,6 +273,11 @@
-                     bool keep_old = false,
-                     bool nonreg = false );
-+  CubitStatus hollow( DLIList<Body*>& bodies,
-+                      DLIList<RefFace*> faces_to_remove,
-+                      DLIList<Body*>& new_bodies,
-+                      double depth);
-   //! \brief Thickens a sheet body (surface) into a solid body.  Can do both directions.
-   CubitStatus thicken( DLIList<Body*>& bodies,
-                        DLIList<Body*>& new_bodies,
-Index: ACIS_SRC/AcisModifyEngine.cpp
---- ACIS_SRC/AcisModifyEngine.cpp	(revision 5396)
-+++ ACIS_SRC/AcisModifyEngine.cpp	(working copy)
More information about the cgma-dev
