[cgma-dev] OCC MacOS compile successful
Rajeev Jain
jain at mcs.anl.gov
Mon Feb 27 14:22:16 CST 2012
Right, I was missing DYLD_LBRARY_PATH. CGM configures now, make runs for a while then I get the following error:
In copy constructor 'BRepBuilderAPI_MakeShape::BRepBuilderAPI_MakeShape(const BRepBuilderAPI_MakeShape&)':
/Users/rajeevjain/Downloads/OpenCASCADE652/ros/install/inc/TopTools_ListOfShape.hxx:112: error: 'TopTools_ListOfShape::TopTools_ListOfShape(const TopTools_ListOfShape&)' is private
/Users/rajeevjain/Downloads/OpenCASCADE652/ros/install/inc/BRepBuilderAPI_MakeShape.hxx:38: error: within this context
/Users/rajeevjain/Downloads/OpenCASCADE652/ros/install/inc/BRepBuilderAPI_MakeWire.hxx: In copy constructor 'BRepBuilderAPI_MakeWire::BRepBuilderAPI_MakeWire(const BRepBuilderAPI_MakeWire&)':
/Users/rajeevjain/Downloads/OpenCASCADE652/ros/install/inc/BRepBuilderAPI_MakeWire.hxx:66: note: synthesized method 'BRepBuilderAPI_MakeShape::BRepBuilderAPI_MakeShape(const BRepBuilderAPI_MakeShape&)' first required here
/Users/rajeevjain/Downloads/OpenCASCADE652/ros/install/inc/TopTools_ListOfShape.hxx: In copy constructor 'BRepLib_MakeShape::BRepLib_MakeShape(const BRepLib_MakeShape&)':
/Users/rajeevjain/Downloads/OpenCASCADE652/ros/install/inc/BRepLib_MakeShape.hxx:46: error: within this context
/Users/rajeevjain/Downloads/OpenCASCADE652/ros/install/inc/BRepLib_MakeWire.hxx: In copy constructor 'BRepLib_MakeWire::BRepLib_MakeWire(const BRepLib_MakeWire&)':
/Users/rajeevjain/Downloads/OpenCASCADE652/ros/install/inc/BRepLib_MakeWire.hxx:81: note: synthesized method 'BRepLib_MakeShape::BRepLib_MakeShape(const BRepLib_MakeShape&)' first required here
/Users/rajeevjain/Downloads/OpenCASCADE652/ros/install/inc/TopTools_MapOfShape.hxx:88: error: 'TopTools_MapOfShape::TopTools_MapOfShape(const TopTools_MapOfShape&)' is private
/Users/rajeevjain/Downloads/OpenCASCADE652/ros/install/inc/BRepLib_MakeWire.hxx:81: error: within this context
/Users/rajeevjain/Downloads/OpenCASCADE652/ros/install/inc/BRepBuilderAPI_MakeWire.hxx:66: note: synthesized method 'BRepLib_MakeWire::BRepLib_MakeWire(const BRepLib_MakeWire&)' first required here
OCCModifyEngine.cpp: In member function 'CubitStatus OCCModifyEngine::do_loft(BRepOffsetAPI_ThruSections&, DLIList<DLIList<TopoDS_Edge*>*>) const':
OCCModifyEngine.cpp:952: note: synthesized method 'BRepBuilderAPI_MakeWire::BRepBuilderAPI_MakeWire(const BRepBuilderAPI_MakeWire&)' first required here
make[4]: *** [OCCModifyEngine.lo] Error 1
make[3]: *** [all-recursive] Error 1
make[2]: *** [all] Error 2
make[1]: *** [all-recursive] Error 1
make: *** [all] Error 2
Rajeev
>________________________________
> From: Jane Hu <janejhu at gmail.com>
>To: Rajeev Jain <jain at mcs.anl.gov>
>Cc: Tim Tautges <tautges at mcs.anl.gov>; CGMA Development <cgma-dev at mcs.anl.gov>; James Tautges <jamesdtautges at gmail.com>
>Sent: Monday, February 27, 2012 9:42 AM
>Subject: Re: [cgma-dev] OCC MacOS compile successful
>Hi, Rajeev:
>It's good news that you are able to build OCC in Mac!
>I saw this error before too in building CGM on OCC on Linux. However, it turned out to be a set up problem. Can you look at config.log, and check if it said that you are using the correctly OCC library? You have to set the LD_LIBRARY_PATH to include your new build directory.
>Hope it helps.
>Jane
>On Fri, Feb 24, 2012 at 12:21 PM, Rajeev Jain <jain at mcs.anl.gov> wrote:
>Thanks, James.
>>I was able to build OCC. Did you get CGM to work?
>>Configuring CGM I get this:
>>checking if OpenCascade requires -lpthread... configure: error: Cannot link libTKKernel with Standard_Mutex
>>Rajeev
>>> From: Tim Tautges <tautges at mcs.anl.gov>
>>>To: CGMA Development <cgma-dev at mcs.anl.gov>; James Tautges <jamesdtautges at gmail.com>
>>>Sent: Friday, January 6, 2012 9:10 AM
>>>Subject: [cgma-dev] OCC MacOS compile successful
>>>Hi all,
>>> Good news, last night my son James, hacker extraordinaire, got OCC 6.5.2 to compile successfully on MacOS. The details:
>>>- Snow leopard, gcc4.2, OCC6.5.2 (straight from the OCC download page)
>>>- Besides the following changes, follow the steps on http://opencascade.blogspot.com/2010/04/porting-on-macos.html
>>>- Run "autoreconf -fi" in the ros folder and then "aclocal", "automake", and "autoconf"
>>>- Add the following code to the platform specific part of ros/src/OSD/OSD_Chronometer.cxx:
>>>#ifdef __MACH__
>>># include <time.h>
>>># include <sys/time.h>
>>># include <mach/clock.h>
>>># include <mach/mach.h>
>>>#endif
>>>- And then add this code to the OSD_Chronometer::GetThreadCPU function:
>>>#elif defined(__MACH__)
>>> struct timespec ts;
>>> clock_serv_t cclock;
>>> mach_timespec_t mts;
>>> host_get_clock_service(mach_host_self(), CALENDAR_CLOCK,
&cclock);
>>> clock_get_time(cclock, &mts);
>>> mach_port_deallocate(mach_task_self(), cclock);
>>> ts.tv_sec = mts.tv_sec;
>>> ts.tv_nsec = mts.tv_nsec;
>>>- Proceed to configure, make, and install
>>>The new version of OSD_Chronometer.cxx is attached.
>>>We haven't built or tested CGM on top of this, but that's next.
>>>- tim
>>>"You will keep in perfect peace him whose mind is
>>> steadfast, because he trusts in you." Isaiah 26:3
>>> Tim Tautges Argonne National Laboratory
>>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>>>phone (gvoice): (608)
354-1459 1500 Engineering Dr.
>>> fax: (608) 263-4499 Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120227/a59d92b9/attachment.htm>
More information about the cgma-dev
