[cgma-dev] buildbot failure in cgm-occ: failed compile test
Iulian Grindeanu iulian at mcs.anl.gov
Wed Feb 1 09:55:54 CST 2012
/CGM/test> offset_curves Geometry engine set to: OpenCascade 6.5 WARNING: Direction qualifier ignored - only valid for one straight curve ERROR: Opencascade can't calculate one offset curve for each input curve. It's a limitation, try use other type of curves to offset. ERROR: Must have an offset direction for any straight curve. WARNING: Direction qualifier ignored - only valid for one straight curve offset_curves: offset_curves.cpp:198: CubitStatus make_Point(): Assertion `fabs(d-28.2743) < 0.0001' failed. Aborted backtrace #0 0x00007fffee5c5a75 in *__GI_raise (sig=<value optimized out>) at ../nptl/sysdeps/unix/sysv/linux/raise.c:64 #1 0x00007fffee5c95c0 in *__GI_abort () at abort.c:92 #2 0x00007fffee5be941 in *__GI___assert_fail (assertion=0x81ce0a "fabs(d-28.2743) < 0.0001", file=<value optimized out>, line=198, function=0x81d020 "CubitStatus make_Point()") at assert.c:81 #3 0x0000000000421923 in make_Point () at offset_curves.cpp:198 #4 0x0000000000420ba2 in main (argc=1, argv=0x7fffffffdfb8) at offset_curves.cpp:51 (gdb) frame 3 #3 0x0000000000421923 in make_Point () at offset_curves.cpp:198 the value of d in the test is (gdb) p d $1 = 34.557519189487721 fabs(d-28.2743) < 0.0001 is false ----- Original Message -----
| Hi, Iulian
| Can you see where the testcase fails, it passed in my machine. Thanks.
| Jane
| On Wed, Feb 1, 2012 at 12:50 AM, < cgma-dev at mcs.anl.gov > wrote:
| | Fathom : cgm-occ build #713
| | Results: failed compile test
| | Buildslave: gnep
| | Revision: None
| | Reason: The Nightly scheduler named 'nightly' triggered this build
| | Log
| | Excerpt
| | libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o operation
| | operation.o -L/home/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib
| | ../.libs/libcgm.a
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTL.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEP.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEP209.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEPAttr.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEPBase.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKIGES.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKXSBase.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBinL.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKCAF.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKLCAF.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKV3d.so
| | -lGLU
| | -lGL /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKCDF.so
| | CADE6.5.0/gcc/lib/libTKV2d.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKService.so
| | -lXmu
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKHLR.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKOffset.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKFillet.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKFeat.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBool.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKShHealing.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBO.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKPrim.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKMesh.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKTopAlgo.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKGeomAlgo.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBRep.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKGeomBase.so
| | occ/OpenCASCADE6.5.0/gcc/lib/libTKG3d.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKG2d.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKMath.so
| | /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKernel.so
| | -lstdc++ -lrt -lXt -lX11 -ldl -lpthread -lm -Wl,-rpath
| | -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib -Wl,-rpath
| | g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom -I../itaps
| | -DLITTLE_ENDIAN=BYTE_ORDER -DTEMPLATE_DEFS_INCLUDED -DHAVE_OCC
| | -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -DSRCDIR=. -I../geom
| | -I../util -I../init -I../geom/ACIS -I../geom/virtual -I../geom/facet
| | -I../geom/Cholla -I../geom/OCC -I.
| | -I/home/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/inc -D_OCC64
| | -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H
| | '-DTEST_ENGINE="OCC"' -Wall -pipe -pedantic -O2 -DNDEBUG -MT
| | brick_occ-brick.o -MD -MP -MF .deps/brick_occ-brick.Tpo -c -o
| | brick_occ-brick.o `test -f 'brick.cpp' || echo './'`brick.cpp
| | /usr/include/c++/4.4/bits/stl_algo.h: In function ‘int main(int,
| | char**)’:
| | /usr/include/c++/4.4/bits/stl_algo.h:194: warning: array subscript
| | is
| | above array bounds
| | is
| | above array bounds
| | mv -f .deps/brick_occ-brick.Tpo .deps/brick_occ-brick.Po
| | /bin/sh ../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic
| | -O2
| | -DNDEBUG -L/home/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib -o
| | brick_occ brick_occ-brick.o ../ libcgm.la -lTKernel -lm
| | libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o brick_occ
| | brick_occ-brick.o
| | ../.libs/libcgm.a
| | -lGLU
| | SCADE6.5.0/gcc/lib/libTKV2d.so
| | -lXmu
| | /occ/OpenCASCADE6.5.0/gcc/lib/libTKG3d.so
| | -DTEST_OCC -Wall -pipe -pedantic -O2 -DNDEBUG -MT
| | merge_occ-merge_test.o -MD -MP -MF .deps/merge_occ-merge_test.Tpo -c
| | -o merge_occ-merge_test.o `test -f 'merge_test.cpp' || echo
| | './'`merge_test.cpp
| | mv -f .deps/merge_occ-merge_test.Tpo .deps/merge_occ-merge_test.Po
| | -O2
| | merge_occ merge_occ-merge_test.o ../ libcgm.la -lTKernel -lm
| | libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o merge_occ
| | ../.libs/libcgm.a
| | -lGLU
| | penCASCADE6.5.0/gcc/lib/libTKV2d.so
| | -lXmu
| | /homes/fathom/3rd
| | party/occ/OpenCASCADE6.5.0/gcc/lib/libTKG3d.so
| | '-DTEST_ENGINE="ACIS"' -Wall -pipe -pedantic -O2 -DNDEBUG -MT
| | point_project-point_project.o -MD -MP -MF
| | .deps/point_project-point_project.Tpo -c -o
| | point_project-point_project.o `test -f 'point_project.cpp' || echo
| | './'`point_project.cpp
| | point_project.cpp: In function ‘CubitStatus point_project()’:
| | point_project.cpp:102: warning: ‘surf’ may be used uninitialized in
| | this function
| | mv -f .deps/point_project-point_project.Tpo
| | .deps/point_project-point_project.Po
| | -O2
| | point_project point_project-point_project.o ../ libcgm.la -lTKernel
| | -lm
| | point_project
| | ../.libs/libcgm.a
| | -lGLU
| | /homes/fathom/3rd
| | party/occ/OpenCASCADE6.5.0/gcc/lib/libTKV2d.so
| | -lXmu
| | /homes
| | /fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKG3d.so
| | -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -Wall
| | -pipe -pedantic -O2 -DNDEBUG -MT imprint_bug.o -MD -MP -MF
| | .deps/imprint_bug.Tpo -c -o imprint_bug.o imprint_bug.cpp
| | imprint_bug.cpp: In function ‘CubitStatus make_Point()’:
| | imprint_bug.cpp:105: warning: unused variable ‘ome’
| | mv -f .deps/imprint_bug.Tpo .deps/imprint_bug.Po
| | -O2
| | imprint_bug imprint_bug.o ../ libcgm.la -lTKernel -lm
| | libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o imprint_bug
| | imprint_bug.o -L/home/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib
| | ../.libs/libcgm.a
| | -lGLU
| | -lXmu
| | ...make check-TESTS
| | make[3]: Entering directory
| | `/disks/itaps-buildslave/cgm-occ/build/test'
| | make[4]: Entering directory
| | [0;32mPASS [m: init
| | [0;32mPASS [m: sheet
| | [0;32mPASS [m: brick_facet
| | [0;32mPASS [m: merge_facet
| | [0;32mPASS [m: attribute_to_file
| | [0;32mPASS [m: attribute_to_buffer
| | [0;32mPASS [m: modify
| | [0;32mPASS [m: subtract
| | [0;32mPASS [m: makept
| | /bin/sh: line 1: 11279 Aborted "$tst" > offset_curves.log-t 2>&1
| | [0;31mFAIL [m: offset_curves
| | [0;32mPASS [m: r_w
| | [0;32mPASS [m: test_occ
| | [0;32mPASS [m: operation
| | [0;32mPASS [m: brick_occ
| | [0;32mPASS [m: merge_occ
| | [0;32mPASS [m: point_project
| | [0;32mPASS [m: imprint_bug
| | [0;31m=======================
| | 1 of 17 tests failed
| | See test/test-suite.log
| | [mmake[4]: *** [test-suite.log] Error 1
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120201/1317b813/attachment-0001.htm>
More information about the cgma-dev mailing list
