[cgma-dev] buildbot failure in cgm-occ: failed compile test
Jane Hu janejhu at gmail.com
Wed Feb 1 09:31:47 CST 2012
Hi, Iulian
Can you see where the testcase fails, it passed in my machine. Thanks.
Jane
On Wed, Feb 1, 2012 at 12:50 AM, <cgma-dev at mcs.anl.gov> wrote:
> Fathom <http://gnep.mcs.anl.gov:8010/>: cgm-occ<http://gnep.mcs.anl.gov:8010/builders/cgm-occ>build
> #713 <http://gnep.mcs.anl.gov:8010/builders/cgm-occ/builds/713> *Results:*failed
> compile test *Buildslave:*gnep *Revision:*None *Reason:*The Nightly
> scheduler named 'nightly' triggered this build Log Excerpt
> libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o operation operation.o  -L/home/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib ../.libs/libcgm.a /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTL.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEP.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEP209.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEPAttr.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEPBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKIGES.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKXSBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBinL.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKCAF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKLCAF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKV3d.so -lGLU -lGL /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKCDF.so /homes/fathom/3rdparty/occ/OpenCAS
>  CADE6.5.0/gcc/lib/libTKV2d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKService.so -lXmu /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKHLR.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKOffset.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKFillet.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKFeat.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBool.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKShHealing.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBO.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKPrim.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKMesh.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKTopAlgo.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKGeomAlgo.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBRep.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKGeomBase.so /homes/fathom/3rdparty/
>  occ/OpenCASCADE6.5.0/gcc/lib/libTKG3d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKG2d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKMath.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKernel.so -lstdc++ -lrt -lXt -lX11 -ldl -lpthread -lm -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib
> g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom -I../itaps   -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL  -DSRCDIR=. -I../geom -I../util -I../init -I../geom/ACIS -I../geom/virtual -I../geom/facet -I../geom/Cholla -I../geom/OCC -I. -I/home/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H '-DTEST_ENGINE="OCC"'   -Wall -pipe -pedantic -O2 -DNDEBUG -MT brick_occ-brick.o -MD -MP -MF .deps/brick_occ-brick.Tpo -c -o brick_occ-brick.o `test -f 'brick.cpp' || echo './'`brick.cpp
> /usr/include/c++/4.4/bits/stl_algo.h: In function ‘int main(int, char**)’:
> /usr/include/c++/4.4/bits/stl_algo.h:194: warning: array subscript is above array bounds
> mv -f .deps/brick_occ-brick.Tpo .deps/brick_occ-brick.Po
> /bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG -L/home/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib   -o brick_occ brick_occ-brick.o ../libcgm.la -lTKernel -lm
> libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o brick_occ brick_occ-brick.o  -L/home/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib ../.libs/libcgm.a /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTL.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEP.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEP209.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEPAttr.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEPBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKIGES.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKXSBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBinL.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKCAF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKLCAF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKV3d.so -lGLU -lGL /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKCDF.so /homes/fathom/3rdparty/occ/OpenCA
>  SCADE6.5.0/gcc/lib/libTKV2d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKService.so -lXmu /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKHLR.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKOffset.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKFillet.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKFeat.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBool.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKShHealing.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBO.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKPrim.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKMesh.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKTopAlgo.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKGeomAlgo.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBRep.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKGeomBase.so /homes/fathom/3rdparty
>  /occ/OpenCASCADE6.5.0/gcc/lib/libTKG3d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKG2d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKMath.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKernel.so -lstdc++ -lrt -lXt -lX11 -ldl -lpthread -lm -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib
> g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom -I../itaps   -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL  -DSRCDIR=. -I../geom -I../util -I../init -I../geom/ACIS -I../geom/virtual -I../geom/facet -I../geom/Cholla -I../geom/OCC -I. -I/home/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H -DTEST_OCC   -Wall -pipe -pedantic -O2 -DNDEBUG -MT merge_occ-merge_test.o -MD -MP -MF .deps/merge_occ-merge_test.Tpo -c -o merge_occ-merge_test.o `test -f 'merge_test.cpp' || echo './'`merge_test.cpp
> mv -f .deps/merge_occ-merge_test.Tpo .deps/merge_occ-merge_test.Po
> /bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG -L/home/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib   -o merge_occ merge_occ-merge_test.o ../libcgm.la -lTKernel -lm
> libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o merge_occ merge_occ-merge_test.o  -L/home/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib ../.libs/libcgm.a /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTL.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEP.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEP209.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEPAttr.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEPBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKIGES.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKXSBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBinL.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKCAF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKLCAF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKV3d.so -lGLU -lGL /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKCDF.so /homes/fathom/3rdparty/occ/O
>  penCASCADE6.5.0/gcc/lib/libTKV2d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKService.so -lXmu /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKHLR.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKOffset.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKFillet.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKFeat.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBool.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKShHealing.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBO.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKPrim.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKMesh.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKTopAlgo.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKGeomAlgo.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBRep.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKGeomBase.so /homes/fathom/3rd
>  party/occ/OpenCASCADE6.5.0/gcc/lib/libTKG3d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKG2d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKMath.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKernel.so -lstdc++ -lrt -lXt -lX11 -ldl -lpthread -lm -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib
> g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom -I../itaps   -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL  -DSRCDIR=. -I../geom -I../util -I../init -I../geom/ACIS -I../geom/virtual -I../geom/facet -I../geom/Cholla -I../geom/OCC -I. -I/home/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H '-DTEST_ENGINE="ACIS"'   -Wall -pipe -pedantic -O2 -DNDEBUG -MT point_project-point_project.o -MD -MP -MF .deps/point_project-point_project.Tpo -c -o point_project-point_project.o `test -f 'point_project.cpp' || echo './'`point_project.cpp
> point_project.cpp: In function ‘CubitStatus point_project()’:
> point_project.cpp:102: warning: ‘surf’ may be used uninitialized in this function
> mv -f .deps/point_project-point_project.Tpo .deps/point_project-point_project.Po
> /bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG -L/home/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib   -o point_project point_project-point_project.o ../libcgm.la -lTKernel -lm
> libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o point_project point_project-point_project.o  -L/home/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib ../.libs/libcgm.a /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTL.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEP.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEP209.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEPAttr.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEPBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKIGES.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKXSBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBinL.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKCAF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKLCAF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKV3d.so -lGLU -lGL /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKCDF.so /homes/fathom/3rd
>  party/occ/OpenCASCADE6.5.0/gcc/lib/libTKV2d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKService.so -lXmu /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKHLR.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKOffset.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKFillet.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKFeat.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBool.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKShHealing.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBO.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKPrim.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKMesh.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKTopAlgo.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKGeomAlgo.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBRep.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKGeomBase.so /homes
>  /fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKG3d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKG2d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKMath.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKernel.so -lstdc++ -lrt -lXt -lX11 -ldl -lpthread -lm -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib
> g++ -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom -I../itaps  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL  -DSRCDIR=. -I../geom -I../util -I../init -I../geom/ACIS -I../geom/virtual -I../geom/facet -I../geom/Cholla -I../geom/OCC -I. -I/home/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/inc -D_OCC64 -DHAVE_IOSTREAM -DHAVE_IOMANIP -DHAVE_FSTREAM -DHAVE_LIMITS_H   -Wall -pipe -pedantic -O2 -DNDEBUG -MT imprint_bug.o -MD -MP -MF .deps/imprint_bug.Tpo -c -o imprint_bug.o imprint_bug.cpp
> imprint_bug.cpp: In function ‘CubitStatus make_Point()’:
> imprint_bug.cpp:105: warning: unused variable ‘ome’
> mv -f .deps/imprint_bug.Tpo .deps/imprint_bug.Po
> /bin/sh ../libtool  --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -O2 -DNDEBUG -L/home/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib   -o imprint_bug imprint_bug.o ../libcgm.la -lTKernel -lm
> libtool: link: g++ -Wall -pipe -pedantic -O2 -DNDEBUG -o imprint_bug imprint_bug.o  -L/home/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib ../.libs/libcgm.a /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTL.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEP.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEP209.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEPAttr.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKSTEPBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKIGES.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKXSBase.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBinL.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKCAF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKLCAF.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKV3d.so -lGLU -lGL /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKCDF.so /homes/fathom/3rdparty/occ/OpenCASC
>  ADE6.5.0/gcc/lib/libTKV2d.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKService.so -lXmu /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKHLR.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKOffset.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKFillet.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKFeat.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBool.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKShHealing.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBO.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKPrim.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKMesh.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKTopAlgo.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKGeomAlgo.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKBRep.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.0/gcc/lib/libTKGeomBase.so /homes/fathom/3rdparty/o
>  ...make  check-TESTS
> make[3]: Entering directory `/disks/itaps-buildslave/cgm-occ/build/test'
> make[4]: Entering directory `/disks/itaps-buildslave/cgm-occ/build/test'
>  [0;32mPASS [m: init
>  [0;32mPASS [m: sheet
>  [0;32mPASS [m: brick_facet
>  [0;32mPASS [m: merge_facet
>  [0;32mPASS [m: attribute_to_file
>  [0;32mPASS [m: attribute_to_buffer
>  [0;32mPASS [m: modify
>  [0;32mPASS [m: subtract
>  [0;32mPASS [m: makept
> /bin/sh: line 1: 11279 Aborted                 "$tst" > offset_curves.log-t 2>&1
>  [0;31mFAIL [m: offset_curves
>  [0;32mPASS [m: r_w
>  [0;32mPASS [m: test_occ
>  [0;32mPASS [m: operation
>  [0;32mPASS [m: brick_occ
>  [0;32mPASS [m: merge_occ
>  [0;32mPASS [m: point_project
>  [0;32mPASS [m: imprint_bug
>  [0;31m=======================
> 1 of 17 tests failed
> See test/test-suite.log
>  [mmake[4]: *** [test-suite.log] Error 1
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120201/fc86bf17/attachment-0001.htm>
More information about the cgma-dev mailing list
