[cgma-dev] Meshquite and iGeom
    Iulian Grindeanu
    iulian at mcs.anl.gov
    Tue Jan 17 09:20:34 CST 2012
----- Original Message -----
| Hi Dan,
| What is your configuration? Did you build cgm with OpenCascade or with
| Cubit/Acis?
| I think it is OpenCascade.
| So are you trying to associate all mesh vertices with the closest
| surface geometry?
| Can you send the code you are using to test this?
| iBase_REGION corresponds to a volume entity in iGeom or to a 3D solid
| element in iMesh (3D topological entity)
| From what I see, the geometry and mesh are pretty close to each other.
| How are you deciding what nodes are on the boundary? Are you using
| Skinner in moab?
I was wrong; vtk file model is about 1000 times bigger. What units are you using? Maybe I am doing something wrong when converting igs file. Are you reading igs file directly in cgm ? Again, can you send us your code? | Iulian
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120117/d88e6a0c/attachment.htm>
More information about the cgma-dev
