[cgma-dev] OpenCascade 6.5.2
    Jed Brown
    jedbrown at mcs.anl.gov
    Mon Jan  9 10:08:14 CST 2012
On Mon, Jan 9, 2012 at 09:46, Jane Hu <janejhu at gmail.com> wrote:
> Hi, Jed:
> Current cgm code is compatible to OpenCascade6.5.1 and lower. In
> OpenCascade 6.5.2, the API calls all added a geometry tolerance to the
> arguments, which is reasonable. We need to update our current source code
> to accommodate the changes.
> I will let you know when this is done.
Great, thank you.
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120109/5987387c/attachment.htm>
More information about the cgma-dev
