[cgma-dev] OpenCascade 6.5.2
    Jane Hu
    janejhu at gmail.com
    Mon Jan  9 09:46:11 CST 2012
Hi, Jed:
Current cgm code is compatible to OpenCascade6.5.1 and lower. In
OpenCascade 6.5.2, the API calls all added a geometry tolerance to the
arguments, which is reasonable. We need to update our current source code
to accommodate the changes.
I will let you know when this is done.
Thank you!
Jane
On Sat, Jan 7, 2012 at 2:55 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> I get type conversion errors when building current (r5293) with
> OpenCascade 6.5.2, compiler errors attached.
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20120109/7ea728ad/attachment.htm>
More information about the cgma-dev
