[cgma-dev] r5288 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com jiangtao_ma at yahoo.com
Fri Jan 6 09:23:16 CST 2012
Author: janehu
Date: 2012-01-06 09:23:12 -0600 (Fri, 06 Jan 2012)
New Revision: 5288
Modified:
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Fixed the issue brought up by Boyd Tidwell about make curve by points should pass all points instead of using those points as control points for B-Spline. Passed make check in cgm.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2012-01-05 21:41:38 UTC (rev 5287)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2012-01-06 15:23:12 UTC (rev 5288)
@@ -388,7 +388,7 @@
   gp_Pnt pt;
   int size = 2+vector_list.size();
-  TColgp_Array1OfPnt points(1, size);
+  Handle(TColgp_HArray1OfPnt) points = new TColgp_HArray1OfPnt(1, size);
   CubitVector vector;
   CubitVector closest_location;
   for(int i = 1; i <= size; i++)
@@ -417,19 +417,22 @@
        pt.SetCoord(closest_location.x(), closest_location.y(), closest_location.z()) ;
-     points.SetValue(i, pt);
+     points->SetValue(i, pt);
   //make curve according to the curve type.
   if(curve_type == SPLINE_CURVE_TYPE)
-    Geom_BezierCurve BezierCurve(points);
-    Geom_BezierCurve* curve =  new Geom_BezierCurve(BezierCurve);
-    Handle(Geom_BoundedCurve) curve_ptr(curve);
-    TopoDS_Vertex * vt1 = occ_point1->get_TopoDS_Vertex();
-    TopoDS_Vertex * vt2 = occ_point2->get_TopoDS_Vertex();
-    TopoDS_Edge new_edge = BRepBuilderAPI_MakeEdge(curve_ptr, *vt1, *vt2);
-    return OCCQueryEngine::instance()->populate_topology_bridge(new_edge, true);
+    GeomAPI_Interpolate spline(points, CUBIT_FALSE, TOL);
+    spline.Perform();
+    if(spline.IsDone())
+      Handle_Geom_BSplineCurve curve = spline.Curve();
+      TopoDS_Vertex * vt1 = occ_point1->get_TopoDS_Vertex();
+      TopoDS_Vertex * vt2 = occ_point2->get_TopoDS_Vertex();
+      TopoDS_Edge new_edge = BRepBuilderAPI_MakeEdge(curve, *vt1, *vt2);
+      return OCCQueryEngine::instance()->populate_topology_bridge(new_edge, true);
   return (Curve*) NULL;
More information about the cgma-dev mailing list
