[cgma-dev] r5178 - cgm/trunk/itaps
jiangtao_ma at yahoo.com
Thu Sep 29 12:15:20 CDT 2011
Author: janehu
Date: 2011-09-29 12:15:19 -0500 (Thu, 29 Sep 2011)
New Revision: 5178
Modified:
cgm/trunk/itaps/iGeom.h
cgm/trunk/itaps/iGeom_CGMA.cc
Log:
Added a iGeom_getEntClosestPtTrimmed interface to call closest_point_trimmed function for surfaces. This is to avoid projecting point onto void space of a surface. Per Shengyong's request.
Modified: cgm/trunk/itaps/iGeom.h
--- cgm/trunk/itaps/iGeom.h 2011-09-28 22:01:52 UTC (rev 5177)
+++ cgm/trunk/itaps/iGeom.h 2011-09-29 17:15:19 UTC (rev 5178)
@@ -454,7 +454,7 @@
int* err );
/**\brief Get closest point for an array of entities and points
+ * For surfaces, closest point could be on the void space inside it.
* Get closest point for an array of entities and points. If either the
* number of entities or number of coordinate triples is unity, then all
* points or entities are queried for that entity or point, respectively,
@@ -471,6 +471,35 @@
* \param on_coordinates_size Occupied size of closest point array
* \param *err Pointer to error type returned from function
+ void iGeom_getEntClosestPtTrimmed( iGeom_Instance instance,
+ iBase_EntityHandle entity_handle,
+ double near_x,
+ double near_y,
+ double near_z,
+ double* on_x,
+ double* on_y,
+ double* on_z,
+ int* err );
+ /**\brief Get closest point for an array of entities and points
+ * For surfaces, it made sure the closest point in on surface.
+ * Get closest point for an array of entities and points. If either the
+ * number of entities or number of coordinate triples is unity, then all
+ * points or entities are queried for that entity or point, respectively,
+ * otherwise each point corresponds to each entity. storage_order should be
+ * a value in the iBase_StorageOrder enum.
+ * \param instance iGeom instance handle
+ * \param entity_handles Entity(ies) being queried
+ * \param entity_handles_size Number of entities being queried
+ * \param storage_order Storage order of input points
+ * \param near_coordinates Coordinates of starting point(s)
+ * \param near_coordinates_size Number of values in near_coordinates array
+ * \param on_coordinates Coordinates of closest points
+ * \param on_coordinates_allocated Allocated size of closest point array
+ * \param on_coordinates_size Occupied size of closest point array
+ * \param *err Pointer to error type returned from function
void iGeom_getArrClosestPt( iGeom_Instance instance,
iBase_EntityHandle const* entity_handles,
int entity_handles_size,
Modified: cgm/trunk/itaps/iGeom_CGMA.cc
More information about the cgma-dev
